I have Float A Ford auxilliary shocks on my 1923 Toring with small drum axles and Ruckstell.
I would like to keep the shocks but install some form of auxilliary brakes. Rocky Mountains will not work.
Like to know if anyone else has done this.
Float a Ford Auxilliary Brakes
- First Name: craig
- Last Name: leach
Re: Float a Ford Auxilliary Brakes
Hi Grant,
Judging from the pics I found of Float-A-Ford's A-C, Stronghold & APCO small drum Auxiliary brakes should fit you may need to remove a little
from the underside where it can't be seen for clearance. The A-Cs I believe are available.
- First Name: Kent
- Last Name: Palazzo
The AC Brakes are available from Bennet Machine in Oklahoma. I got a set from Daniel, great guy to deal with.Craig Leach wrote: ↑Wed Jul 23, 2025 2:18 pmHi Grant,
