Modern LED Bulb Numbers
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sun Sep 14, 2025 5:58 am
Can anyone post the bulb numbers for LED bulbs used in the Ford dash light and the C.M. Hall made Ford stoplight ? I'm sure they are all single contact, and I think, all straight pin, but different candlepower.
Moxie26
Last Name: Jablonski
Re: Modern LED Bulb Numbers
Post by Moxie26 » Sun Sep 14, 2025 8:43 am
Do a search on forum and you'll come up with answer with bulbs others may use.... https://www.logolites.com/ ..,... viewtopic.php?f=2&t=49668.
Moxie26
Post by Moxie26 » Tue Sep 16, 2025 7:52 pm
Hey Terry, how you doing... Any progress with your LED bulb application?
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Sep 16, 2025 9:29 pm
Robert, I had previously ordered the adjustable LED headlight bulbs from Logo Lights, so I went back to their webssite. They do have an LED small miniature bulb that will work for the dash light and a tail light, but not for a stop light bulb. If need be, I'll just use a regular incandescent bulb for the stop light function.
RVA23T
Last Name: C
Post by RVA23T » Wed Sep 17, 2025 6:19 am
A second source:
www.ledlight.com
And here is the 6 volt search result link:
https://www.ledlight.com/6-volt-positiv ... ights.aspx
Moxie26
Post by Moxie26 » Wed Sep 17, 2025 7:43 am
Aware that their stoplight bulb is not available at this time, was the question asked on when they would have replenish stock available?
