Starter switch hot
Art Ebeling
First Name: Art
Last Name: Ebeling
Starter switch hot
Post by Art Ebeling » Sat Oct 18, 2025 5:32 pm
I am working on a 26 that will start but turns over pretty slow but the starter will only drag if tried again a second time and the starter switch gets red hot. The cable to the battery gets hot also. I cleaned all the connections, same thing. The starter does not feel hot. Bad starter? Art
Re: Starter switch hot
Post by TXGOAT2 » Sat Oct 18, 2025 5:50 pm
It could be a starter problem, but it could be the switch or the connections to the switch. If the starter switch gets very hot it is probably damaged. If the cables are the correct size, they should not get hot, and the switch should not get hot. NOTE: The starter is not designed to operate for more than about 10 seconds at a time. Grinding on it will overheat it, and will over-strain the battery. If the engine does not start in about ten seconds of cranking or less, stop cranking and let the starter cool down while you determine why the engine won't start. For the starting system to work as it should, all the parts, including cables, switch, battery, starter, and all ground points must be in good condition. The battery must be of adequate size and in good condition and fully charged. The engine needs to be in a good state of tune so that it will start readily, and the generator needs to be working as it should to keep the battery in a good state of charge.
Post by TXGOAT2 » Sat Oct 18, 2025 5:53 pm
The starter can get hot internally and still be cool to the touch on the outside. The starter should not be operated continuously for more than 10 seconds at a time without letting it rest for a minute or so before trying again.
Post by TXGOAT2 » Sat Oct 18, 2025 5:55 pm
If the timing is advanced too far when cranking the engine, the engine can fire against the starter. An easy way to check for this is to crank the engine with the ignition key off. If it cranks faster, the timing needs to be retarded more while cranking.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sat Oct 18, 2025 6:23 pm
Are you using the proper size 6 volt battery cables?.... Just by looking, they are a thicker diameter than conventional 12-volt battery cables.
Post by Jerry VanOoteghem » Sat Oct 18, 2025 8:04 pm
Does the cable from the starter switch to the starter get hot as well? If it does, then the problem is likely in the starter. If not, then the issue is maybe within the switch itself.
Post by John kuehn » Sat Oct 18, 2025 8:40 pm
Do you know if the starter has ever been gone through? That could be the issue. Original starters and original radiators wear out after nearly 100 years. From what you’re saying it sounds more like the starter than the starter switch.
Post by speedytinc » Sat Oct 18, 2025 9:32 pm
Original or repop type replacement switch? Repops regularly fail/burn out.
From what i have seen failures are a matter of when.
Originals can be easily refurbished if the bus bar is fairly solid.
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Sat Oct 18, 2025 9:54 pm
When considering battery/starter cable size, one needs to know maximum amperage and length of the cable.
From a reliable model T source: 6 volt starting amperage may well exceed 250 amps and maybe as high as 300amps. For 12 volt systems cut those amperages in half.
Remember, KEEP the cable length as SHORT as practicable. Longer cable will need to be a larger size.
Remember, the LOWER THE NUMBER means LARGER cable AND HIGHER the number means the cable will be smaller.
There are many color coded graphs that coordinate amperage, length, and size. Google it.
ALWAYS use larger cable than you think you will need. The added safety margin just may make a BIG difference when you need it most.
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Oct 19, 2025 11:33 am
Hi Art,
Try doing a volt drop test to isolate the issue. You will need help with someone to push the switch. Set your multimeter to DC volts & test along
the circuit. Battery to cable, cable to switch, across the switch, switch to starter. When you put the test leads on each section you will get no
volts until the switch is pushed. If you get more than a few tenths of a volt when cranking then you have resistance in that part of the circuit.
If you get several volts then you have high resistance in that part of the circuit. Resistance x volts & amps + heat.
Post by speedytinc » Sun Oct 19, 2025 12:52 pm
Try a jump test between the 2 starter switch terminals. (Heavy cable or jumper cable)
That will rule in/out the switch & starter.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Sun Oct 19, 2025 12:53 pm
I was just posting that. Lol
Post by speedytinc » Sun Oct 19, 2025 12:54 pm
A hot switch tells me insulators grounding or a bad internal connection.
Post by Jerry VanOoteghem » Mon Oct 20, 2025 12:10 pm
Art,
Several folks here have tried to help you. Do you have any feedback for us?
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Tue Oct 21, 2025 7:57 am
I took both cables off of the switch and cleaned the terminals and cable ends. they were corroded. I checked the switch with an ohmmeter and it worked correctly. After putting it all back together and several starts the starter button did not get hot and the starter turns like it should. I think I had a combination of corroded connections, combinded with a freshly rebuilt tight engine and too many attempts to get it started. Art
Post by TXGOAT2 » Tue Oct 21, 2025 9:57 am
Automotive starters have a short duty cycle. That was true in 1912 and it's true today. 10 seconds of continuous cranking is about the limit. Wait a minute or two after ten seconds of continuous cranking before trying again. The engine should start almost instantly. The battery, starter motor, and the starter switch are not designed for extended engagement.
Moxie26
Post by Moxie26 » Tue Oct 21, 2025 10:06 am
Clean fresh connections means a lot, ... positive and negative cables
Post by TXGOAT2 » Tue Oct 21, 2025 10:13 am
Indeed they do. Beyond that, the engine needs to have a good electrical ground to the frame.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Tue Oct 21, 2025 10:44 am
Do you have a braided ground cable? They lose conductivity and heat up. If you have one check it. Had to replace mine for that reason and the cranking improved. The starter is of course the load but you say it's not getting hot. Right now I'm with wiring/cables.
Post by Jerry VanOoteghem » Tue Oct 21, 2025 5:14 pm
Happy to see you've got it solved :)
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Tue Oct 21, 2025 6:53 pm
Yes it does have a braded negative cable. I will get it replaced. Art
Post by Scott_Conger » Tue Oct 21, 2025 7:12 pm
This being true, you do not need a new ground cable - also, no matter how "ugly" it is, if a braided ground is clean on both ends/connections, and has no broken strands or loss of strand cross-section due to heavy corrosion (rare), it cannot do anything other than conduct voltage/current as though it was brand new.
Edit: since braided ground cables are lead plated, they will soon exhibit a very light powdery surface, lead oxide, if kept in a very damp location for extended periods. This typically has zero practical effect on the electrical system. If, however, strands are broken, lead plating is compromised, and green (ish) corrosion is found then the copper has been compromised and will have some effect in current carrying ability - that reduction in efficiency goes up with loss of conductor cross-section and contamination through corrosion. Sometimes, this results in the need to replace the strap if conditions are particularly bad. This problem does occasionally occur but is typically overblown in the hobby.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Post by Charlie B in N.J. » Wed Oct 22, 2025 5:26 pm
My braided cable looked perfect but it would get hot when cranking and replacing it improved the cranking speed. The cable had resistance and it looked fine.
