What will a Model T run on?
Todd Touchberry
First Name: Todd
Last Name: Touchberry
* REQUIRED* Type and Year of Model Ts owned: 1919. And 1920
Post by Todd Touchberry » Tue Oct 28, 2025 1:52 pm
Todd Touchberry
Daisy Mae
First Name: Kurt
Last Name: Andersson
Board Member Since: 2024
Re: What will a Model T run on?
Post by Daisy Mae » Tue Oct 28, 2025 3:32 pm
Reminds me of a story from my youth. My bro's & I welded up and sold mini-bike frames as kids, so our garage was full of various contraptions, all of which constantly depleted my dad's gas can, much to his consternation.
We paid regular visits to the local auto salvage yards snooping around collecting things. Opened a car trunk once and found a HUGE display bottle of Aramis cologne...like a gallon of the stuff!! We'd heard the stories about antique engines burning anything, so, no gas in Dad's gas can meant in the Aramis went! Who'd a thunk? The mini-bikes ran OK on the stuff!!
The only issue was, a few passes up & down the street and the entire neighborhood smelled like a New Orleans Bordello!! Lord our neighbors just loved us.
Todd Touchberry
First Name: Todd
Post by Todd Touchberry » Tue Oct 28, 2025 7:24 pm
VERY COOL STORY
Todd Touchberry
Todd Touchberry
First Name: Todd
Post by Todd Touchberry » Fri Oct 31, 2025 8:28 am
I got in so much trouble on a mini bike one time!
Todd Touchberry
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Fri Oct 31, 2025 10:08 am
You didn't happen to live in CA in the 70's did ya? LOL
Post by TXGOAT2 » Sat Nov 01, 2025 2:10 pm
Once warmed up, a Model T will run on about any volatile flammable liquid or flammable vapor. I was able to get a John Deere Model E 1 1/2 horse power stationary engine to run on rubbing alcohol, which is 70% isopropyl alcohol and 30% water. A Model T would run reasonably well on Everclear or other high proof liquor, as long as it didn't contain sugar.
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Sun Nov 02, 2025 10:22 pm
They use to run them on kerosene after they were warmed up. Kerosene was cheap in the day but way more than gasoline to day.
Post by TXGOAT2 » Mon Nov 03, 2025 8:58 am
When I was a kid, a few old gas stations kept a drum of kerosene on hand. It sold for about 9 cents a gallon.
jab35
Last Name: Bartsch
Post by jab35 » Mon Nov 03, 2025 10:56 am
My father talked about his father (my grandpop) using kerosene as engine coolant during winter in central Wisconsin. Pop said 'it smelled a little and was kinda hard on the hoses'. jb
dykker5502
First Name: Michael
Last Name: Deichmann
Post by dykker5502 » Tue Nov 04, 2025 8:29 am
In Sweden you can get E85 gasolin (85% ethanol) and I've tried to run one of my T's on it. Ran perfectly - maybe to the richer side which is expected. It could even coldstart the next morning.
Ford Model T 1914 Touring
Post by TXGOAT2 » Tue Nov 04, 2025 9:30 am
I would not store a car with E 85 in the gas tank, especially in a humid environment. The car can be run on it, but power and fuel mileage will be reduced. If E85 is cheap enough, it might be economical to run the car on it, if you drive the car often and you are willing to do what is necessary to prevent problems with moisture absorption and decay. E85 does best in a high compression engine with intake air heat. While it can be used in a Model T, E 85 is not well-suited for vehicles with atmospheric vented fuel tanks and carburetors, since atmospheric moisture can pollute the E85 blend, and essential blend components can be lost to evaporation, both of which will hasten decay of the E85. If you do use E 85, use all of it as soon as practical, and switch to E 15 or straight gasoline in the car if it is to be stored for more than a couple of weeks.
If I wanted to run E 85 in a Model T, I'd want a high compression head and an intake air heat pipe, and I'd want the engine to run around 200F. A distributor and a hot coil that would allow plug gaps around .035" would probably be helpful, too
dykker5502
First Name: Michael
Post by dykker5502 » Tue Nov 04, 2025 11:05 am
Now the topic was about driving a T on alternative fuels. I agree about the storage if it for example over winter have various temperatures. That evem goes for E10 or even E5.
But storage was not the topic here.
Post by TXGOAT2 » Tue Nov 04, 2025 2:31 pm
The main issue with E 85 in a T would be storage related. I think it's worth a mention any time using E 85 in early cars is discussed. If E 85 was available here, and cheap enough to give more net miles per DOLLAR, I'd use it in my T, subject to the aforementioned caveats.
Post by TXGOAT2 » Tue Nov 04, 2025 2:34 pm
How does the cost of E 85 compare to regular gasoline in your area? Does it contain an "odorant"? All gasoline sold for on- road use in the USA does contain a chemical "odorant", which give the exhaust a very strong, foul odor where a catalytic converter is not present.
Todd Touchberry
First Name: Todd
Post by Todd Touchberry » Wed Nov 05, 2025 9:30 am
no sir. lol
Todd Touchberry
Post by Steve Jelf » Wed Nov 05, 2025 10:25 am
Misled by the low price, I once tried E-85 in my Camry. The mileage was so bad that the actual cost was higher than E-10. Doesn't ethanol gas go bad? Not if you use it up and don't let it sit for months. Never a problem in my 1915 T.
Post by TXGOAT2 » Wed Nov 05, 2025 10:31 am
Calculate your COST PER MILE. (I would also consider diminished performance and perhaps increased ring and piston wear)
Model T's don't have a lot of excess horsepower, so reduced power output is something to consider, especially in hilly areas or if you often carry loads. Ethanol blends over 10% have a well-deserved reputation for damaging fuel systems NOT DESIGNED for such blends!
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Wed Nov 05, 2025 4:39 pm
Bottom line, anything running E85 vs gas/10% will get way worse mileage given ethanol only has about 2/3 the equivalent BTU's to gas. This also therefore equates to reduced power output. So, unless E85 is less than 2/3 the cost of gas, or you don't mind wasting $$$ from a mileage perspective or making your engine work harder, or you're doing so for altruistic environmental reasons., the question becomes, "why??".
The second issue with ethanol is that it is exceedingly hydroscopic, and in an open/vented system you best be burning it in a hurry unless you like water in your fuel system.
The third issue with ethanol is that it is caustic to many components of older fuel systems, most notably rubber.
Fuel lines, mechanical fuel pumps, carb components etc are highly at risk to ethanol....fire anyone???
The 4th issue with ethanol is alcohol has a much lower boiling point than gas. Vapor lock in gravity fed, or fuel under vacuum (such as w/mechanical pumps), or near heat sources, will be a significantly greater probability with ethanol compared to gas.
