1912 Front Hub How Do I Remove The Rac?
Bill Everett
First Name: Bill
Last Name: Everett
Board Member Since: 2011
Post by Bill Everett » Tue Nov 11, 2025 3:20 pm
How do I remove the race seen in the picture? Ny help woold be great!
Re: 1912 Front Hub How Do I Remove The Rac?
Post by speedytinc » Tue Nov 11, 2025 3:35 pm
Grind a bar/plate to fit in the race about 1/2 way down. Weld onto the race with a wire welder.
Tap it out against the welded plate/bar with a rod/pipe from the opposite side.
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Tue Nov 11, 2025 4:22 pm
put a couple of welds on it with the wire welder and it will fall out
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Nov 11, 2025 8:20 pm
I second welding in a bar, works great, used it multiple times to remove something stuck like that.
It never fights after that unless it is defective already.
Loftfield
First Name: Thomas
Last Name: Loftfield
Post by Loftfield » Wed Nov 12, 2025 7:51 am
No welder? Use rotary carbide rasp to cut into the race, tap with hammer to loosen race. If no success use a bigger hammer.
