New model T transmission brake drums??
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Sat Nov 15, 2025 12:52 am
How do I get ahold of the guy that makes new transmission brake drums? I want to buy one for my speedster project
thx
frontyboy
Re: New model T transmission brake drums??
Post by Jerry VanOoteghem » Sat Nov 15, 2025 7:57 am
thx
frontyboy
https://www.davesrestorationandmachine.com/
Dave Nolting. Great guy!
Also... https://www.jandm-machine.com/custom_works.html
Great products as well.
Post by John kuehn » Sat Nov 15, 2025 11:52 am
Dave’s restoration and machine advertises regularly in the MTFCA Vintage Ford magazine.
frontyboy
First Name: dick
Last Name: dock
Post by frontyboy » Sun Nov 16, 2025 2:20 am
Thnx for the quick replay. I will contact both early this week
frontyboy.
Last Name: Juhl
Post by Oldav8tor » Sun Nov 16, 2025 10:08 am
Look closely at the other drums. It might be a good time to replace all three.
Post by Allan » Sun Nov 16, 2025 8:33 pm
A new drum is only part of the story. The outer diameter of the driven plate forms part of the brake drum surface. Is a new driven plate available to match the new drums? If not, a new drum will mean a step down to the worn OD of the driven plate, not an ideal situation for the band lining.
Before new drums were available, I used to have the drum/driven plate assembly ground together to make the full width brake band surface. I compensate for the reduced diameter of the drums by fitting a rolled sheet metal spacer between the band and the lining to maintain the original range of adjustment for the bands.
