Ross steering box
WorldChamp1914
First Name: Gary
Last Name: Hagen
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
Ross steering box
Post by WorldChamp1914 » Fri Dec 05, 2025 8:59 pm
Is Les Schubert still working on the reproduction Ross steering box?
Re: Ross steering box
Post by Jerry VanOoteghem » Sat Dec 06, 2025 8:44 am
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Dec 06, 2025 10:29 am
One has been installed in a car and it has been found to be very nice to drive. Unfortunately it only fits the 26-7 T.
As part of the installation it needs a frame rail “doubler” (about 2 ft long). A easy source can be cut from another 26-7 frame. The “drag link” needs to be either twisted standard T or I’ve used a pair of model T tie rod ends and custom made piece of tubing.
I apologize for not responding earlier to people about this earlier, but I’ve been distracted with other projects
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Sat Dec 06, 2025 12:12 pm
Les,
Do you have any pictures? Is the plan to market them at some point?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Dec 06, 2025 1:03 pm
I am only doing the one production run so maybe 6 will be available
WorldChamp1914
First Name: Gary
Last Name: Hagen
Post by WorldChamp1914 » Sun Dec 07, 2025 2:13 am
Was there a Ross steering for pre- 26-27 cars?
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Dec 07, 2025 11:53 pm
At one time my wife's speedster HAD a Ross steering box. Unfortunately it was removed before I bought the car for her. The Ross steering box had been replaced with a Vega steering box. It works fine. But unfortunately is not an era correct steering assembly.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Dec 08, 2025 7:27 am
Ross steering boxes can be found in various types that are easy to adapt, ie, early Jeeps, early Willys, Crosleys, Cushman, early golf carts of various manufacturers, even old tractors used them.
Just do a little research
Jamie Maxwell
First Name: Jamie
Last Name: Maxwell
* REQUIRED* Type and Year of Model Ts owned: 1919 touring
Post by Jamie Maxwell » Mon Dec 08, 2025 9:31 am
Allis Chalmers B,C, and CA tractors used both Ross and Gemmer steering gears !
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Dec 08, 2025 10:22 am
If it does not turn in the direction you require, use a bell crank from a Jeep forward cab. Just follow the 90 degree rule of steering geometry in the push/pull at the attachment points. The internet has all of this.
