wheel spreader no longer needed
Jim Byrne
First Name: Jim
Last Name: Byrne
* REQUIRED* Type and Year of Model Ts owned: 1917 model t
Post by Jim Byrne » Sun Dec 07, 2025 7:15 pm
I just found one thanks everyone for the reply's
Re: WTB wheel spreader
Post by speedytinc » Sun Dec 07, 2025 7:18 pm
What's a wheel spreader? Spoke jack? rim spreader? or something else?
Post by Allan » Sun Dec 07, 2025 11:37 pm
If it is a rim spreader you are after, they come in different sizes, according to the rims you are on which you are working.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Dec 08, 2025 2:01 pm
Hi Jim,
Are these what you are looking for? Most often referred to as a rim spreader even if their main function is compressing the rim to remove it
from the tire & then push it back out to lock the rim. I would be willing to part with the lever action one ( left)as it is less fun to use but the
screw type I want to keep for future use. I'm in the metro Phx. Az. area if you get there occasionally. These are not a tool that gets used very
often so if you get to this area once in a while I could loan you one?
Jim Byrne
First Name: Jim
Last Name: Byrne
Post by Jim Byrne » Mon Dec 08, 2025 2:13 pm
Thanks but I just found one
Re: wheel spreader no longer needed
Post by Scott_Conger » Mon Dec 08, 2025 2:24 pm
Jim
READ how to use one, ask for help, be careful
fail to do the above will rapidly lead to an ad "WTB new rims"
these things can do a lot of damage in a very short time if misused
Jim Byrne
First Name: Jim
Last Name: Byrne
Post by Jim Byrne » Mon Dec 08, 2025 7:25 pm
Scott, I would love to find instructions---I see a lot of photos with the arms in different positions, some obviously wrong
Post by Scott_Conger » Mon Dec 08, 2025 8:31 pm
Post by RajoRacer » Mon Dec 08, 2025 9:44 pm
One step I always do after tire mounting on a split rim is TO NOT inflate to full pressure (32 lbs.) until I've remounted the tire & rim back onto the wheel and bolted it back on !
