Radiator /water pump
Oldrusty26
First Name: Travis
Last Name: Melnick
* REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT etc...
Board Member Since: 2012
Post by Oldrusty26 » Mon Dec 08, 2025 11:22 am
Not to open a fresh can of worms on an old subject ( I’m going to anyhow ) I’ve ordered a new flat tube radiator for my roadster pick up from brass works , my engine currently has a water pump , question is , will the water pump restrict the cooling capabilities of the new radiator and should I remove it , or would it be ok to just leave it on ? I realize that they are not needed , but will it hurt anything to be left alone ?
Thanks in advance !!
AndyClary
First Name: Andrew
Last Name: Clary
Re: Radiator /water pump
Post by AndyClary » Mon Dec 08, 2025 11:32 am
If you have a good radiator you won’t need the water pump any more.
Andy
Post by speedytinc » Mon Dec 08, 2025 11:34 am
Maybe. Depends on the water pump. I would remove the pump. My bias.
I might suggest you install the new radiator & run it with the pump. If you have a hint of not cooling as it should, remove the pump out of necessity.
Post by TRDxB2 » Mon Dec 08, 2025 12:00 pm
I seriously doubt if your water pump would restrict flow, after all they were supposed to help. So did yours help or is it the reason to get a new radiator? If you don't need it consider it as a possible point of failure, broken belt would cause some restriction. Model T design > "keep it simple"
Post by Jerry VanOoteghem » Mon Dec 08, 2025 12:02 pm
If the pump is in good shape and doing its job, it probably wouldn't hurt to leave it on. I have found that they're a good "ice breaker" and a great way to start conversations with new people. ;)
Some may suggest adding a thermostat, which I personally would never do. But, that's just me...
Post by TXGOAT2 » Mon Dec 08, 2025 12:03 pm
The pump is not needed with a good radiator. If you choose to keep using it, be sure the packing does not leak air in when the engine is running at higher speeds. Water pumps are capable of leaking air into the coolant when the engine is running, yet not leak when it is stopped. Aerated coolant can lead to rapid corrosion,steam pockets, and false boilovers. A water pump needs good bearings and good packing running on a good shaft to work properly. I'd want a thermostat on any T running a waterpump. Over cooling is bad for engines. If you don't choose to run the water pump, sell it, don't throw it away. They are a useful accessory for some applications.
Post by TXGOAT2 » Mon Dec 08, 2025 12:07 pm
A water pump defeats the temperature regulation inherent with a thermosyphon system. Overcooling can result, which causes a number of issues. A properly fitted thermostat used with a water pump will prevent overcooling, cavitation, coolant aeration, and coolant loss at the overflow pipe. Overcooling contributes to carbon formation, sludge formation, plug fouling, and poor fuel economy.
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Mon Dec 08, 2025 12:21 pm
Went through several radiators in my hoard , they all leaked in one way or another , my recently deceased father was insistent that we put a water pump on , so he rebuilt it ( he was a machinist and mechanic ) and installed it on the vehicle . Never really drove it any length of time , so once I started putting it back together , I left the pump on , just ordered a new radiator and will take it off if it will hurt anything , but would like to leave it on because my dad had rebuilt it , if that makes any sense , 😜
Post by Norman Kling » Mon Dec 08, 2025 12:36 pm
If your block, head and radiator are clean of rust and other dirt, you do not need a water pump. Where we live we have hard water which leaves deposits. So I use 50 50 antifreeze all year around and if I need to add some, I use distilled water. Of course, that depends on where you live and the temperature. You might need more anti freeze. I use the green stuff.Anyway, if everything is clean If all else is in good condition, a water pump is just something which can leak and drain your cooling system.
Post by Jerry VanOoteghem » Mon Dec 08, 2025 12:42 pm
... but would like to leave it on because my dad had rebuilt it , if that makes any sense , 😜
That makes complete sense, my friend. I leave mine on as well...
Post by TXGOAT2 » Mon Dec 08, 2025 1:16 pm
To sum up, a water pump in good condition will do no harm. I would use a 180F thermostat with a 1/8" bypass hole. Another consideration: A water pump would allow use of a hot water heater, provided you have a generator and battery.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Dec 08, 2025 2:52 pm
Hi Travis,
Makes all the sense in the world if your dad rebuilt it and insisted it be on by all means run it for that reason. Most water pumps for Ts are no
more than a water circulators & should not impair cooling. If it circulates water to fast as in pushes water out the overflow just cut the impeller
down. Keep in mind the packing needs to be watched & adjusted from time to time as with greasing the bushing/s. I think honoring your dad is
is way more important than Henry Ford wishes.
Post by TXGOAT2 » Mon Dec 08, 2025 3:13 pm
Henry Ford used water pumps whenever there was a practical need. Starting with the 1928 Model A, every Ford had a water pump. In 1932, Ford introduced a V8, and every one of them had TWO water pumps! All Ford V8s through 1953 had two water pumps.
Post by TXGOAT2 » Tue Dec 09, 2025 7:45 pm
A comparison of specific HP output:
Model T: 0.11 hp per cubic inch displacement (No water pump)
Model A: 0.20 HP per cubic inch displacement (Water pump)
1938 V8: 0.38 HP per cubic inch displacement (Dual water pumps)
Ford, and most everyone else, installed water pumps as specific output increased.
In the case of some tractor engines, where size and weight weren't so important, water pumps were not used, and the designers relied on large radiators, fans, and high capacity water jackets to control heat. Some early tractors, like the Farmall Regular and 2 cylinder John Deeres, used an overhead valve engine. OHV engines generally put less heat into the head and block than do comparable L head designs of similar displacement and output. Many early tractors were designed to burn kerosene, and it was advantageous to have the engine run as close to the boiling point as was practical.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Dec 09, 2025 11:25 pm
Please note that the Ford N R S all had water pumps!!
Post by Wayne Sheldon » Wed Dec 10, 2025 2:09 am
A couple points of clarification.
MOST water pumps intended for use in a model T won't hurt the function in any significant sense, as long as it is in good condition, functioning properly, and doesn't leak.
However, some poorly designed pumps can restrict flow badly enough that even with the best radiator you can get the car will not cool adequately. I have a couple that are so restrictive I would NEVER consider using them. A few were made to leave room on the side of the engine for things like magnetos or early after-market starter/generators. Some of those are also too restrictive. Some of the ones that mount on the front of the head don't work well, but may or may not restrict water flow.
If it is one of the typical common types that mounts on the left side of the block going straight into the water inlet on the side of the block? It is "probably" okay to use.
With a caveat.
The thermosyphon cooling is an amazing, and simple, efficient, system. The wonderous thing about it, is that the more cooling that is needed? The faster the water flows.
What almost any added water pump can do, is restrict the water flow when the engine needs the cooling the most.
Consider this. Driving a heavily loaded model T, maybe on a tour or by yourself. It is a hot day, you are doing under 25 mph going up a steady climb a couple miles long.
The engine is turning slow, which means the water pump is turning slow. The load and the ambient temperature has the engine working hard and generating a lot of heat. Without a water pump, the thermosyphon would have the water flowing as fast as the cooling system's restrictions can allow! However, the slow turning water pump restricts the faster flowing of the water just when you need it the most.
Just something to think about.
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Wed Dec 10, 2025 8:50 am
Get rid of it. You will NOT need it. Only possible potential problem would be if the little water passages in the block and/or head are plugged up. You can get an idea of the condition of the head at least by peeking down the outlet while the radiator is off. Flat tube rads are extremely efficient. My '26 Fordor still even has it's original round tube rad that I had it boiled out during a minor repair and wow I can't believe how much better even IT works now. Can run 90 degree days with the moto-meter staying below the "open circle". And yes, the '13 has a flat tube from B.W., and it never even gets close to the "circle" on a 90 degree day. 70 Degree weather the "red stuff" barely makes it to the first line of tiny words that you can't read from 2 feet away :lol:
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Wed Dec 10, 2025 10:20 am
Keep the water pump. It will be appreciated later in life.
My car 1923 touring car has the original round tube radiator and a water pump. It has the original radiator because of the pump and not the other way around. The radiator cools just fine without the pump, but I continue to keep it. The pump reduces the hot spots and the crude caused by the hot spots. I know I will never convince others. Just keep in mind that pumps were originally used on model T's. The elimination reduced cost and the heating engineer probably got a big bonus. Plus, Henry was able to sell more radiators in the future.
Art Mirtes
Post by TXGOAT2 » Wed Dec 10, 2025 10:39 am
The type of pump that mounts on the side of the engine and pushes water into the inlet on the side of the block is best. A good pump will have a round body, or volute about 4" in diameter, and it will have a small diameter pulley to get good impeller speed. A water pump added to a Model T ought to be combined with a thermostat on the water outlet hose to prevent overcooling, provide faster warmup, and to prevent cavitation and overloading the radiator upper tank at higher speeds. A 1/8" bypass hole in the thermostat is a very good idea. It will allow some limited circulation when the thermostat is closed, and it will allow air to escape when filling the system with coolant when the thermostat is closed. The thermosyphon system depends on a very free-flowing cooling system to function as it should.
A water pump might be of considerable benefit on a car operated at high altitudes. At higher altitudes, radiator effectiveness is reduced, and lower atmospheric pressure lowers the boiling point of the coolant. A good water pump and thermostat can offset these problems. While an automotive radiator does radiate heat, it is actually a heat exchanger, and it depends on a high volume of air moving through the core to cool the engine. Thin, high altitude air is not a very effective medium for extracting heat from the radiator core.
Post by TXGOAT2 » Wed Dec 10, 2025 10:44 am
Model Ts with significant performance enhancements will push the limits of the stock cooling system under many conditions. A good water pump and thermostat will enhance the cooling system performance to accommodate the increased cooling demand while retaining the stock radiator.
Post by Steve Jelf » Wed Dec 10, 2025 12:18 pm
My thousands of miles driving a 1915 runabout have been in the mostly near-flat center of the USA. East of Wheeling or west of Denver, would it have been different? Dunno. In all those years, my recored 1915 radiator never hinted that I should install a water pump. But in this case, where a pump is already in place, my suggestion is to leave it in place experimentally. If it never presents a problem, that's no problem. You can leave it. If it becomes problematic, you can ditch it.
Post by TXGOAT2 » Wed Dec 10, 2025 1:30 pm
I suspect that most water pumps installed on Model Ts served the purpose of preventing the radiator from freezing when driving the car with plain water in the cooling system during freezing weather. In sub-freezing weather, the radiator could freeze solid when driving down the road, even as the engine overheated. A water pump kept the radiator from freezing while driving by keeping the water in constant circulation, which the thermosyphon alone would not do.
Good antifreeze was unavailable during the early years of motoring, and many people drained the system whenever they stopped the car for any length of time, and refilled it with warm water, if they had any, when they wanted to use the car. When stopping away from home in freezing weather, they'd put a blanket over the hood and radiator to keep heat in for an hour or so, hoping to prevent freezing. Another good application for a water pump would be a TT running loaded in hot weather or a car in high altitude service.
Post by TXGOAT2 » Wed Dec 10, 2025 4:00 pm
You could check to see if the water pump offered any significant restriction to flow by going for a drive on a warm day with the fan belt removed. I don't think a well designed pump would be a problem. Under most conditions, a Model A with a broken fan belt would not overheat as long as the car was moving down the road. Between thermosyphon flow and the fan turning the water pump, there was enough coolant flow to get by under most conditions.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Wed Dec 10, 2025 6:02 pm
Occasionally, Kerosene was used as a coolant for at least two reasons.
1. It was cheaper than antifreeze.
2. It would not cause further damage it the engine had a leaking head gasket.
3. The freeze point freeze point of kerosene is very low.
Just don't let it catch fire. If it did, they would jump out of the car and let it burn.
Art Mirtes
Post by TXGOAT2 » Wed Dec 10, 2025 6:47 pm
Kerosene has a low specific heat, making it a poor coolant, but better than nothing. I don't know what the boiling point is, but I'd think it's lower than water. I don't know how much kerosene expands with heat compared to water. The expansion ratio would affect its behavior in a thermosyphon system. It's low in viscosity, but I'd think it's higher than water. On balance, an alcohol/glycerin/water mix would be better.... but in those days kerosene was dirt cheap, and everyone had some around. It's good for bee stings, too....
Dodge
First Name: Dodge
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Post by Dodge » Thu Dec 11, 2025 1:07 am
I have a water pump on one of my cars. I put it on to keep it from overheating in one of our local parades in Corte Madera Ca.
The route is almost 3 miles long and take 2.5 hrs. to complete. It has the water pump with 180 degree thermosat.
It used to overheat before the water pump.
Just sayin........
Loftfield
First Name: Thomas
Last Name: Loftfield
Post by Loftfield » Thu Dec 11, 2025 8:08 am
Here's my story. I have never used a water pump, have always had good radiators, fortunately. I bought a Model T which had a water pump attached. I thought nothing of it, drove the car around the farm to see how things worked, got back to the barn car boiling over. The water pump was immediately removed, drove some more, again bad boiling. Finally removed the radiator in the course of which a totally frozen thermostat was encountered in the outlet fitting. Long story short, the valves had burned from no cooling. Finally had to have the engine rebuilt, all for a stupid thermostat. Throw away the water pump and don't even buy a thermostat. If Mr. Ford didn't put it on the car it isn't needed!
Post by TXGOAT2 » Thu Dec 11, 2025 9:48 am
A thermostat is needed when using a water pump in anything but hot weather to prevent over-cooling. Obviously, the thermostat needs to work as it should. I would drill a 1/8" hole in the thermostat flange to allow some coolant bypass and to allow air to escape when filling the radiator, and to assure that hot water reaches the thermostat in a timely manner during warmup. A bubble of air or steam trapped under a closed thermostat could prevent it from opening. Drilling the flange will prevent that. Thermostats are reliable, widely available at low cost, and easily tested. If the engine was run hot enough to burn a valve, let alone several of them, I'd look for cracked seats. Even with a totally stuck thermostat, water would be forced out of the radiator overflow once the engine reached the boiling point, assuming there was any water in it. Filling the cooling system with water would be difficult with a closed thermostat with no provision for air to escape, and a system that was low on coolant could allow the engine to get very hot while the thermostat remained closed.
It is important to make sure that there is provision made for air and steam bubbles to get past the thermostat when it is closed. Many thermostats have a very small bypass hole, but I would not depend on that when using one in a Model T. I'd want a 1/8" hole in the flange. Unlike most other applications, the Model T has no provision for air or coolant to bypass a closed thermostat, so the thermostat must be modified to suit the application.
Post by TXGOAT2 » Thu Dec 11, 2025 10:02 am
A water pump will not cause an engine to overheat. Neither will a properly adapted thermostat. When acquiring a car that has had a water pump added, I'd look for a thermostat and for a clogged radiator. If the radiator was good, and no thermostat was present, I'd install a 180F thermostat with a drilled flange. Then I'd remove the pan access and check for sludge.
Post by TXGOAT2 » Thu Dec 11, 2025 10:08 am
I would not use a thermostat on a Model T unless it had a water pump. I would not run a Model T with a thermostat UNLESS it had a water pump AND the thermostat flange was drilled to allow air to escape from the water jackets and to allow some coolant bypass for more uniform warmup before the thermostat opened. Water pumps have their uses. The fact that one is not needed under most circumstances does not change that fact.
Post by TRDxB2 » Fri Dec 12, 2025 12:56 am
The answer to your question all depends on which water pump you have, and there were lots...
The impellers on many were an open design, so they wouldn't restrict water flow in the event of a belt failure
By Stan Howe on Thursday, November 01, 2007
While I don't run a pump usually, it is fair to say that some of them work a lot better than others and that they DO circulate the water. Some of them don't look to me like they would have ever moved much water but some of them move a lot of water, even at idle or just above. I have a bunch of them, have always been going to put together a display. Now I have a bead blaster again I hope to get some of them cleaned up and mounted on a board or something. The trick on the packing is to use the correct packing, water pump packing. If the shaft is smooth and the packing good, they won't leak and will still turn. Just because it is dark and cold out this morning I'm going to post these pictures of some of the pump collection at the Speedy Bill Museum in Lincoln, Nebraska. This isn't all of them. Maybe it will inspire me to go out and turn the heat on in the shop and do something today.
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Sat Dec 13, 2025 6:46 pm
Awsome !! That’s a fantastic display of pumps . There’s several dozen in my parts hoard
Post by John kuehn » Sat Dec 13, 2025 7:02 pm
From a purists point of view (which I’m not) does an accessory water pump knock off points at a Model T car show? I’m in the crowd that believes is a good radiator is the best option for an engine that may be suspected of over heating or cooling troubles.
I’ve had two in the past to no avail until I bought a new Bergs radiator and that ended my overheating issue.
Post by TXGOAT2 » Sat Dec 13, 2025 7:09 pm
I'd think any non-factory accessory would cost points, if as-built "originality" was the judging criteria.
Post by TXGOAT2 » Sat Dec 13, 2025 7:10 pm
Are Model Ts allowed at Pebble Beach?
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Sat Dec 13, 2025 8:39 pm
If invited.
Post by TXGOAT2 » Sat Dec 13, 2025 8:51 pm
My phone is NOT ringing.....
