FS MISCELLANEOUS PARTS
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Dec 08, 2025 6:21 pm
Miscellaneous parts as described below. Prices are as indicated. Domestic shipping will be $8.50 USPO Priority Flat Rate. Combine items and save on shipping. Mark Chaffin (951) 805-0928
Front outer wheel bearing sets $45.00 per set / SOLD
Good steering pitman arms $40.00 each.
Early straight spindles arms $30.00 each
1914-1915 front pan support bracket NOS $10.00
Mark Chaffin
Last Name: Chaffin
Re: FS MISCELLANEOUS PARTS
Post by Mark Chaffin » Mon Dec 08, 2025 6:26 pm
Excellent Universal Joint $75.00 / (SOLD)
Early front wheel ball bearing sets and parts $100. (SOLD)
Front wheel dust seal set and rear axle inner seal set new $15.00 (SOLD)
26/27 gas tank screen replacement kit $20.00 (SOLD)
Last edited by Mark Chaffin on Mon Dec 08, 2025 11:18 pm, edited 3 times in total.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Dec 08, 2025 6:27 pm
1915-1918 push pull light switch original $20.00 / (SOLD)
T-Dreamer
First Name: Doug
Last Name: Olsen
* REQUIRED* Type and Year of Model Ts owned: 1920 Touring
Post by T-Dreamer » Mon Dec 08, 2025 7:38 pm
I'll take the u-joint -- will call you in the morning....
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Dec 08, 2025 7:40 pm
Universal Joint going to Doug. Thank you
Perry Goble
First Name: William
Last Name: Goble
Post by Perry Goble » Mon Dec 08, 2025 9:04 pm
I sent you a email . I would to buy the light switch . Thanks Perry
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Dec 08, 2025 9:15 pm
Light Switch going to Perry.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Dec 08, 2025 10:15 pm
Early bearings and seals going to Dean.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Mon Dec 08, 2025 10:58 pm
Mark, I'll definitely take the fuel filter, if still available. I would also take one of the pitman arms "IF" one of them is marked T 929 C. Also interested in pressed steel muffler you had in previous ad.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Dec 08, 2025 11:17 pm
Hi Terry,
I don't believe either pitman arm is marked T929C. I can ship the muffler and fuel filter together.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Dec 08, 2025 11:18 pm
Fuel filter and pressed steel muffler, from other Ad held for Terry.
Gleaner
First Name: ED
Last Name: LARSON
Post by Gleaner » Tue Dec 09, 2025 1:44 am
I will take the front wheel bearings
Email sent
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Tue Dec 09, 2025 9:33 am
Front wheel bearings going to Ed.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Dec 09, 2025 5:52 pm
Mark, Tried to call at 4;45 PM Central time ( 2:45 ) Pacific, today. Got no answer. Checked phone number and it was correct. I'll keep trying. Terry
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Thu Dec 11, 2025 3:58 pm
Mark, i called yesterday and talked to DAVE At the shop. He said to make check to you and not the business, but I could send it to you in care of the business. TODAY, I got an email saying that I owed for the pressed steel muffle and PITMAN ARM #1. The muffler, yes. The pitman arm, NO. The other part I wanted was the sediment bowl screen. Checks in the mail. Terry
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Dec 11, 2025 4:29 pm
Hi Terry,
Send me a text (951) 805-0928 or email rajorepo@netscape.net
Muffler and fuel filter kit being held for you. I will also need your shipping information.
Thank you
