Stewart speedometer
BillM
First Name: BILL
Last Name: MAULDIN
* REQUIRED* Type and Year of Model Ts owned: 1923 Coupe
Stewart speedometer
Post by BillM » Sat Jan 31, 2026 4:07 pm
Am I correct that this swivel is made In October 1919 and is a 6:1 ratio? If so would it be correct to use on a 1923 coupe?
Re: Stewart speedometer
Post by Steve Jelf » Sat Jan 31, 2026 4:59 pm
Russ Furstnow is the speedometer guru (He wrote the book.). If he doesn't see and answer this post, maybe you can contact him through the forum (or Google).
Post by RajoRacer » Sat Jan 31, 2026 6:39 pm
I believe that is a left hand drive & the ratio is 2 & 1/2 to 1.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Sat Jan 31, 2026 7:28 pm
The Stewart Model 1962 swivel is a 6:1 RH ratio. It goes on a 1915-17 Hudson. You need a Model 1913 Stewart swivel for your Ford. I hope this helps. Russ Furstnow
Post by RajoRacer » Sat Jan 31, 2026 8:39 pm
Thanks for the correction, Russ - I was under the impression that Stewart swivels were 2 & 1/2 to 1.
BillM
First Name: BILL
Last Name: MAULDIN
Post by BillM » Sat Jan 31, 2026 10:03 pm
Thank you for that information Russ! I'll be on the lookout for a 1913.
Post by Allan » Sun Feb 01, 2026 2:54 am
On our RHD cars, the swivel is often mounted on the other side to the LHD cars.Same ratio as the pn 1913 but opposite rotation. If you can't find a decent 1913 swivwl, and your cable and housing is long enough, the swivel can be mounted on the opposite side of the car. Without getting into my spares, I cannot recall the PB for this alternative swivel. Perhaps Russ knows.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Sun Feb 01, 2026 8:48 am
Nearly all of the pot metal Stewart swivels look alike, but there are a variety of ratios (from 1:1 to 12:1) and RH and LH types. The 2.5:1 LH part number is Model 1959. Most applications take the Model 1913. I hope this helps, Russ Furstnow
BillM
First Name: BILL
Last Name: MAULDIN
Post by BillM » Sun Feb 01, 2026 11:26 am
Yes it helps a lot. I'll find one somewhere. At least now I know what im looking for. I really appreciate your help guys!
Post by Allan » Sun Feb 01, 2026 11:26 pm
A questions for Russ. The Stewart potmetal swivel housings are the weak link in the Stewart swivels I have found. Can components from LH swivels be swapped into RH swivel housings? Are swivels housings for different ratios interchangeable for other ratio components. This may/may not enable a good swivel to be mix and matched from models.
Post by speedytinc » Mon Feb 02, 2026 8:20 am
In my experience, the pot metal housings are interchangeable.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Mon Feb 02, 2026 8:44 am
John is correct. The pot metal housings are identical. The inner gears determine the ratio of the unit. I have new sets of gears that turn any Stewart swivel into a 2.5:1 RH swivel. These new gear sets were manufactured using original Stewart gears as a pattern. I hope this helps, Russ Furstnow
BigAl
First Name: Alan
Last Name: Stein
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Post by BigAl » Mon Feb 02, 2026 11:09 am
Bill, Sent email through the forum.
Post by Allan » Mon Feb 02, 2026 8:30 pm
Thanks for the confirmation re parts swapping Russ. i suspected it was the case. I guess then that the only difference of consequence is the threaded lower half and the lock nut on the later housings rather than the plain pin with the pressed on collar.
Your spare gear sets will undoubtedly keep many users happy.
Harley_97
First Name: Roger
Last Name: Hallett
* REQUIRED* Type and Year of Model Ts owned: 1924 Runabout, 1917 Runabout
Post by Harley_97 » Tue Feb 03, 2026 10:25 am
I got this Stewart gear with some T items I bought awhile back. I don't see any signs that it has ever been used. The question, is this gear for Model T's or something else.
Thanks Roger
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Tue Feb 03, 2026 4:19 pm
The gear is a 16T9P (#2302) pinion gear. It was not used on a Ford but some other automobile. The Ford uses a 16T8P pinion gear (#2301). I hope this helps, Russ Furstnow
Harley_97
First Name: Roger
Last Name: Hallett
Post by Harley_97 » Wed Feb 04, 2026 9:08 am
Thanks Russ.
