Bosch points needed
goshencars
First Name: dave
Last Name: avon
* REQUIRED* Type and Year of Model Ts owned: 1920
Bosch points needed
Post by goshencars » Thu Jul 25, 2019 9:02 am
I have an old Bosch distributor on my 20 T. I believe it is the 600 series. I am looking for a set of points and condenser for it. The condenser is kidney shaped with a stud that goes thru the wall of the distributor to hold it in place. If anyone knows what the part numbers are and where I can purchase them I would appreciate it. Thanks
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Re: Bosch points needed
Post by Jim Eubanks » Thu Jul 25, 2019 9:39 am
The points are around and show up from time to time but are very pricy. The solution is to remove the present points and cond., have someone that is good as a machinist to drill and tap holes in the old plate for a set of 70s Ply points and cond. They are cheap and plentiful. Also, you can always dress the existing points with a stone.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Jul 25, 2019 10:46 am
I have some “rivet” tungsten contacts. These are just the contacts themselves and you would have to install them to your existing breaker assembly
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Thu Jul 25, 2019 10:59 am
If the kidney condenser is not available you can simply wire another condenser outside of the distributor, it does not have to be IN the distributor, just lengthen the wire and make sure the body of the condenser has good ground contact.
Leo van Stirum, Netherlands
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Jul 25, 2019 1:43 pm
Let me go and look, I am pretty sure I have a couple extra sets.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Jul 25, 2019 7:11 pm
Email sent.
goshencars
First Name: dave
Last Name: avon
Post by goshencars » Thu Jul 25, 2019 7:46 pm
Thanks Hank
