New page: Did I get anything wrong?
Post by Steve Jelf » Thu Aug 01, 2019 11:48 am
Some questions come up repeatedly, so I make a web page about them to avoid having to repeat the answers. Here's the latest. Let me know if you spot anything I should correct.
http://dauntlessgeezer.com/DG113.html
Last Name: Strange
Re: New page: Did I get anything wrong?
Post by CudaMan » Thu Aug 01, 2019 12:20 pm
Thanks for creating that page, Steve. I see you avoided the whole discussion about the different brands of demountable rims and the compatibility of various brands rims and felloes.
Schrader 888 stems are 1/4 inch SHORTER than 777s, not longer. 888 dust covers are also 1/4 inch shorter than 777 covers, so 888 covers won't work on 777 stems, but 777 covers will work on 777 or 888 stems.
DLodge
First Name: Dick
Last Name: Lodge
Post by DLodge » Thu Aug 01, 2019 12:24 pm
"...when demountable rims were intoduced." Typo. Missing an "r"....
Post by Steve Jelf » Thu Aug 01, 2019 3:01 pm
Yes, I wanted to keep it basic. Folks can get into the details with the encyclopedia and online research.
Thanks, gentlemen. Corrections made.
jab35
Last Name: Bartsch
Post by jab35 » Fri Aug 02, 2019 1:23 am
Steve: Nice contribution, excellent photos as usual.
You mention tire sizes and show a tape measurement of a 30" clincher rim. Where does the 30" clincher tire designation come from? clearly not the clincher rim diameter, could you clear that up, please? I believe both clincher and 21" balloon tires had roughly the same outside diameter, so were 30" clinchers designating the diameter of the tire at the trread and 21" balloon designated the diameter of the rim? I never worked with clinchers but find that detail interesting.
I've seen some excellent cross section drawings of clincher tire & rim in Ford service manuals that really illustrate the 'clincher' effect you mention, that illustration might add detail to your page, and perhaps same for split rim and drop center balloon rim and tire. And valve stem-tube-rim cross-section detail?
The Model T and A wire wheel differences still confuse me. You show inside/hubside views of each wheel, could you include photos of A and T wire wheels showing the outside/curbside view of each and a view of each wheel perpendicular to the axle? And what is the measurement of the hub bolt pattern for T and A? Are both A and T wire wheels secured with nuts on studs fixed in the respective hubs, or by studs threaded into the hub flange? I thought T was by nuts to fixed stud is the A similar?
Thanks for the effort to make the information available, jb
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Fri Aug 02, 2019 6:52 am
Thanks Steve from a newbie who has been wondering about all this! Cheers, Bill
Post by Original Smith » Fri Aug 02, 2019 10:16 am
I've not heard of an 888 or 777 dust cover! Yes, there are two different lengths, long and short, but I've not heard of a designation! Where did you get that information Mark?
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Fri Aug 02, 2019 12:02 pm
not so sure that original tires were white. Every picture i've seen they are off-white or gray.
William L Vanderburg
1922 Center Door Sedan
Last Name: Strange
Post by CudaMan » Fri Aug 02, 2019 12:08 pm
My goof, I could have worded it better - the dust covers are not explicitly marked 777 or 888, my intent was to indicate that each stem length had its own corresponding dust cover length. Thanks for helping me clarify. :)
