forum operation question
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Post by Jim Sims » Sun Jan 20, 2019 1:49 pm
After reading a posting, then using the back to forum link this takes me to the top of the page and must scroll down to the next posting. If I use the arrow back it takes me to the posting last read but does not indicate it was read. Is this normal?
George N Lake Ozark
First Name: George P
Last Name: Clipner
Re: forum operation question
Post by George N Lake Ozark » Sun Jan 20, 2019 1:56 pm
I noticed the same thing. Don't know if it is correctable. Hopefully
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Sun Jan 20, 2019 2:01 pm
A post will only indicate as read if you refresh the page.
The BACK button goes back to the previous edition of the page.
Respectfully Submitted,
Be_Zero_Be
Post by Mark Gregush » Sun Jan 20, 2019 2:05 pm
Yes. If you hit the 2019 forum it will take you back to page one and show which ones you have read. If you use the back button it will not show which you have read but will take back to last place you looked. When you are done with your reading session, hit the refresh button on top of page address bar area, it will update any post your have read showing as read. Other forums that use a similar set up often work about the same way.
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Sun Jan 20, 2019 3:13 pm
To add a note that you probably already know - for the above to work as described you must first be signed in.
