'26-'27 brakes
Bruce Compton
Topic author - Posts: 670
- First Name: Bruce
- Last Name: Compton
'26-'27 brakes
I'm sure something has already been posted, but has anyone ever hooked up the emergency brake system to assist the regular service brake. I'm thinking a connection from the pedal to a cross shaft with rods and slots connected to the E brake rods. Bruce
Re: '26-'27 brakes
Yes it has been done. If you look in Lang's or Snyder's (others too), they sell an equalizer to do just that.
https://www.modeltford.com/item/2566BEQ.aspx
https://www.snydersantiqueauto.com/Prod ... l-t/brakes
Susanne
- First Name: Susanne
- Last Name: Rohner
Re: '26-'27 brakes
Years (and years) ago I saw a T set up like that, small drum, not large - the (lined) parking brake would expand at the same time the external band would contract, squeezing the drum. IIRC I asked the car owner about it and he said it worked really good, but it was a so-and-so to get all 4 shoes synchronized so none dragged when released and all applied equal pressure when applied. I actually think it's a great idea if you can get it to work, and are willing to figure out the equalization issues.
Paboot
- First Name: Paul
- Last Name: Bourgeois
- Board Member Since: 2006
Re: '26-'27 brakes
Hey Bruce, just did the install this summer. PM me if you want in the next few days and I will be glad to tell you how it works for me.
My26T@shaw.ca
Regards,PaulB (the Canadian one)
My26T@shaw.ca
Novice
- First Name: Jim
- Last Name: Davis
Re: '26-'27 brakes
Tinkerin Tips Volume I. Copy Right 1988 by Ted Aschman has a project article called. " Poor Man's Rocky Mountain Brakes". Pg 48. where the rear emergency brakes are connected to the regular brake pedal. and the emergency brake leaver still can operate independently of the transmission brake. using a cable operated Brake equalizer. But if the Brake pedal is pressed both transmission brake and rear emergency brakes are activated.
JohnH
- Last Name: Hunter
- Board Member Since: 2002
Re: '26-'27 brakes
I just use the hand brake to stop the car, no need to connect up the pedal.
