Speedometer-gear compatibly question
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Fri Oct 25, 2019 2:05 pm
I’m building a speedster and have a cut off Overland touring body that this speedometer fits perfectly in a factory hole. I was wondering if this gear, 60 tooth 8 pitch, would be the correct gear used with a 1 1/2 to 1 swivel? If not which gear do I need?
Mark Nunn
Last Name: Nunn
Re: Speedometer-gear compatibly question
Post by Mark Nunn » Fri Oct 25, 2019 2:35 pm
Try searching the data in antiquespeedometer.com. They have a lot of information on their site.
John L
Last Name: Leffler
* REQUIRED* Type and Year of Model Ts owned: 1923 Coupe, 1927 Touring
Post by John L » Fri Oct 25, 2019 3:39 pm
Just ask Russ .
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Fri Oct 25, 2019 4:09 pm
I meant 2 1/2- 1 swivel. I think I need a 58 tooth gear for 21” wheels. I’ve got Model A wheels on an Overland axle with a T frame so I can make any gear fit. I just happened to have the one already.
