Greetings All,
This exhaust manifold heater shroud needs to leave my shelf for a new home. I have no idea what engine it is for. It is not for any Ford that I am familiar with. It looks to fit onto an exhaust manifold on the left side of the engine, given the orientation of the cast in letters. I like to think that one of you will know what this will fit to. Someone could be pleased and warmed to have it.
Manufactured by the Remington Auto Heater Corp.
A view from the top.
From the inside.
The front opening.
Thank you for looking and I appreciate your input, Bill.
ID Needed Please, Unknown Manifold Heater Shroud
BHarper
Topic author - Posts: 242
- First Name: Bill
- Last Name: Harper
- * REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Bill Harper
Keene, New Hampshire
Dropacent
- Last Name: Morsher
Re: ID Needed Please, Unknown Manifold Heater Shroud
I think it’s for an early Chevrolet , Bill. Good luck, fun item !
Forensics questions.
One would expect that the manufactures company name would be upright when mounted.
Would it sit on top of a manifold or the side of it. Then what side of the engine left or right?
How would this be attached to a manifold or whatever - there are no bolt holes.
Dropacent
Here is a different brand, but you can see the similar fit.
BHarper
- First Name: Bill
- Last Name: Harper
Hello Tim,
Well, that does look to be "same church, different pew." Thank you so very much.
I wondered if it was for "one of them Bow Tie cars." Now to see if it can find a new home. This forum and all of its members is a wealth of knowledge. Thank you again, Bill
Bill Harper
I would imagine that the "bump-out" should correspond with a bump-out on the exhaust manifold. Since it is near one end of the shroud, not the other, and most intake/exhaust manifold combinations have such bump-outs near the middle where the exhaust is used to warm the crude gasoline of the day, I would surmise that it would be for a six cylinder engine. '20s Buicks were common sixes, but there were many others. And it could be for a '29/'30 Chevrolet?
Just a couple thoughts.
