Dash installation
sheppfour
Topic author - Posts: 22
- First Name: Chris
- Last Name: Sheppard
- * REQUIRED* Type and Year of Model Ts owned: 1919 TT TRUCK
Dash installation
Is there any video of installing a dash in a 19 t roadster ? Do you have to take it loose from the cowl ?
Jim Sims
- First Name: Jim
- Last Name: Sims
- * REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Re: Dash installation
Chris, if you mean the key switch panel, you do not need to remove anything. Call me if you wish.
Jim Sims
Jim Sims
Ruxstel24
- Last Name: Hanlon
I venture to say it's the whole dash panel (that I sent you Chris).
I may be mistaken, but I think you just need to loosen the windshield posts...I don't think the cowl has to come off.
sheppfour
- First Name: Chris
Yes Dave this is the same panel, I found a nice switch for it.
Thanks again for your help . D you have any A model parts ?
Chris
Chris
Ruxstel24
- Last Name: Hanlon
Chris, I have a few things A, not many.
What are you looking for ?
Should be the same as my 21. There are two bolt/screws upper corners top and the two carriage bolts that are part of the windshield bracket mounts one each lower corner.
sheppfour
- First Name: Chris
Thanks for all the help as always
Chris
Chris
