Presoaking linings for transmission bands
T. R. Quick
Topic author - Posts: 13
- First Name: Tom
- Last Name: Quick
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
Is it necessary to presoak linings in oil before they are riveted to bands or can I do it afterwards before I reinstall them ?
Fordor forever
Re: Presoaking linings for transmission bands
I soak mine after lining installation.
T. R. Quick
- First Name: Tom
- Last Name: Quick
Makes more sense to do it then. It would be a mess trying to rivet it to band presoaked
Fordor forever
I soak them after installing.
Leave bands on the loose side.
Pour 2 quarts of oil on them over an hour or 2 time period. (1/4 quart per pour)
Let soak over night (minimum) before running the motor.
JohnH
- Last Name: Hunter
- Board Member Since: 2002
I find it much easier to install the rivets if the linings are pre-soaked for cotton linings.
Mopar_man
- Last Name: Govoni
I let mine soak in oil in a 5 gal bucket overnight.
I soak mine for a couple days in a big Dutch pot before they go into the engine/trans.
I rivet them to the bands and then soak them before installation.
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
I install the linings then soak overnight in neatsfoot oil. Just because that was the recommendation in the era. Any thoughts as to why neatsfoot oil is/was preferable to motor oil ? I have always had good service from cotton linings by doing so.
Get a horse !
Cordes_jeff
- First Name: jeff
- Last Name: cordes
- * REQUIRED* Type and Year of Model Ts owned: 25
I Install them dry in the car. Pour some oil down them once installed. Never had a problem.
