Looking for Winfield Carburetor information
BlackTinLizzie
First Name: William
Last Name: Weiss
Post by BlackTinLizzie » Mon Sep 11, 2023 2:11 pm
I am looking for information on this up draft carburetor that came on a model T speedster.
It's a Winfield Updraft with a 1 5/8 bore.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Looking for Winfield Carburetor information
Post by ThreePedalTapDancer » Mon Sep 11, 2023 2:24 pm
It is a Model V Updraft. Should have the size stamped on the side.
https://www.nwvs.org/Technical/2104WinfieldHV.pdf
BlackTinLizzie
First Name: William
Last Name: Weiss
Post by BlackTinLizzie » Mon Sep 11, 2023 2:28 pm
Thank you very much
Post by Rich Eagle » Mon Sep 11, 2023 2:34 pm
BlackTinLizzie
First Name: William
Last Name: Weiss
Post by BlackTinLizzie » Mon Sep 11, 2023 2:43 pm
Thank you very much
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Sep 11, 2023 8:09 pm
How bout a parts list…
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Sep 11, 2023 8:25 pm
Looks to be in relatively good shape. A couple things I notice are that the flange should have threads (5/16-18 I think) and the fuel inlet has the tube soldered in. Not problems that would stop me from trying to run it tho. The bigger issue with these barrel valve carbs is air leakage at idle. Leaks from the throttle shaft bushings and also from excessive barrel to bore clearance caused by both wear and/or distortion. The flanges are often warped and need surfacing. It’s pretty clear that someone has tried to seal up the throttle shaft bores with the rubber washers.
I once made a new oversize barrel and bored the housing to match on a 4V. It went from idling crappy to idling awesome! I miss that good runnin ol car…😢
BlackTinLizzie
First Name: William
Last Name: Weiss
Post by BlackTinLizzie » Tue Sep 12, 2023 5:22 am
Thanks to all
I am going to try and get the running today
BlackTinLizzie
First Name: William
Last Name: Weiss
Post by BlackTinLizzie » Tue Sep 12, 2023 4:25 pm
Well it runs and idles
Float valve seems to be sticking a little will open it up tomorrow.
BlackTinLizzie
First Name: William
Last Name: Weiss
Post by BlackTinLizzie » Tue Sep 12, 2023 4:29 pm
