Down Draft Intake Manifold Info
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Mon Feb 26, 2024 6:06 pm
Anyone have any idea what this manifold was intended for when new. I don't believe Model A due to the port shape. I know what the carb is from, and dont know if that's a clue or not. My only guess is Iron Duke Chevrolet.
ModelTWoods
First Name: Terry
Last Name: Woods
Re: Down Draft Intake Manifold Info
Post by ModelTWoods » Mon Feb 26, 2024 7:48 pm
The slotted mounting ears look just like a Model A, B or C, but unless the posts are round (they don't look round in pictures), it probably isn't Ford.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Feb 26, 2024 8:55 pm
Looks like a special built for T with the ports enlarged. If it were a factory produced part for some other application there would likely be one or even several casting part numbers, patent dates, etc…
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Mon Feb 26, 2024 9:50 pm
Wish I found it , zoom zoom!
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Mon Feb 26, 2024 10:18 pm
Used one, not the best flow, and can ice up something fierce. Ported block to match. Ran it with a 1 5/8 Master carb with the air screw removed, Giant head and a custom Crower ground A cam (later learned it is a stock grind from an MGA). Set up Fouled plugs like it was protesting CARB. That said, gave power well past 80 mph w/3.63's and a warford. The things we learn!
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Feb 27, 2024 12:52 am
I'm with Kevin 153 Chebby bolts are staggered.
Mike Penserini
Last Name: Penserini
* REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Post by Mike Penserini » Wed Feb 28, 2024 5:44 pm
Steve, It's made to fit a Model T, I have one too, mine is pretty old. I believe it was originally intended as an updraft. Horizontal ports were used in T blocks back in the day. Photo of is the Ed Winfield engine, not mine !
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Mar 01, 2024 1:47 pm
I made variations of this over the last 40 years. My earliest version utilized a Corvair Turbo. Unfortunately I had installed a quite “radical” camshaft and the car had a terrible low speed performance! I have continued to make variations of this design but I now divide it for about 6” of the flow length and then I can use a quite radical camshaft.
Just my experience
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Mar 01, 2024 1:54 pm
