Made new speedster tie-rod ends
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Fri Dec 27, 2024 4:51 pm
I am using model A style steering ends on my 26 speedster project, but needed to get some more clearance between the tie-rod and the radius rods. The most elegant way to do it was use an offset tie-rod end. I didn’t find what I wanted so I made them out of a bar of 4130. They use the standard model A innards and give me 3/8 additional clearance. I think they came out pretty well. I still need to split the lug so I can tighten them on the rod then black oxide them. Here are a couple of shots.
Boring and turning the big end.
Checking the fit
Checking the fit
Blasted and ready for finish, with a stock model A tie-rod end.
Last edited by Reno Speedster on Sat Dec 28, 2024 6:13 pm, edited 1 time in total.
RecklessKelly
Last Name: Maxson
Re: Made new speedster tie-rod ends
Post by RecklessKelly » Sat Dec 28, 2024 1:36 am
Nice work!
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sun Dec 29, 2024 8:41 pm
Yeah, they came out ok. I am waiting for slitting saw for the mill and the black oxide solution to finish them up. This has been a really long running project (I started it back in grad school 20 years or so ago and I am looking forward to getting it done. It’s going to be a mahogany skiff body car so there are a lot of custom parts.
RecklessKelly
Last Name: Maxson
Post by RecklessKelly » Mon Dec 30, 2024 4:15 am
Sounds neat. Have you built the body yet? Strip mahogany construction?
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Tue Dec 31, 2024 10:52 pm
I have the body frame done but it’s not skinned yet. It is going to use wider strips (3-4 inches wide). I had to work out some mechanical things before finishing the body, but I am getting back to it. Here are a couple of shots of the body frame.
From the front
From the front
From the rear
From the rear
The base under construction.
RecklessKelly
Last Name: Maxson
Post by RecklessKelly » Tue Dec 31, 2024 11:54 pm
Nice work. Looks to be master boatbuilding grade construction. You might want to consider okoume or sapele mahogany ply, edge glued strips for skin. It would be the lightest unless you want to go sheetmetal.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Wed Jan 01, 2025 1:40 pm
I am using a thin birch ply for strength overlaid with thin strips of mahogany. I have a pile of old mahogany that was used for wainscoting. It’s not the lightest way to build it, but it will be strong.
