axle gear
Topic author - Posts: 104
- First Name: Vincent
- Last Name: Ryan
- * REQUIRED* Type and Year of Model Ts owned: 1913 TOURING CONVERSION
- Board Member Since: 2023
axle gear
I'm trying to identify the manufacturer of a non ford script gear. It appears to be the same as a ford gear but the axle it came off of was a little shorter and the key slot was different. I'd like to use it but with the proper key.
Re: axle gear
I'm always leery about using non-Ford parts. If it were mine, I'd be looking for a Ford gear.
Re: axle gear
I'd have to agree with Jerry unless you want the practice of possibly having to do it over.
