Ranch Doodlebug Build
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Feb 28, 2025 3:08 pm
I thought I would share a couple pics of the Ranch Doodlebug build. Engine and Ruckstell are done. A huge shout out to Mr. Hank Lee for rebuilding my Zenith carburetor as I know it has been done right and also for modifying my Winfield intake manifold to ensure a proper fit. Hank is indeed an artist. Thanks Hank!
Charlie_26_TT_Ccab
First Name: Charlie
Last Name: Coleman
* REQUIRED* Type and Year of Model Ts owned: 1926 TT C Cab Stakebed Truck
Re: Ranch Doodlebug Build
Post by Charlie_26_TT_Ccab » Sun Mar 02, 2025 12:13 pm
Looks like it’s coming along nicely since
last months visit. Sounds like you have some more shop space now or will shortly.
Best to you and your family, Charlie
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Mar 03, 2025 10:01 am
Hi Charlie,
Yes. Moving along at break neck speed as time permits. I was speaking with Hank Lee the other day and mentioned it would be fun making a one off four wheel drive setup to replace the stock front axle. I mentioned a few ideas I had which were simplistic in nature. Boy did I open up a can of worms! Hank was all over it! Like me, Hank loves a challenge and can't sit idle for more than a few minutes. I would not be surprised if Hank didn't already have a few ideas in motion. I've learned I have to be careful what I say or it ends up on my door step! I sure do admire that guy. I can't even come close to his level of talent and we make many parts for beloved Model T. A bromance indeed! :)
modeltspaz
Last Name: Spaziano
Post by modeltspaz » Mon Mar 03, 2025 10:54 am
Mark,
Check out the Livingood 4 W. D. setup for Model T Fords. A few years back, I believe that the original manufacturer's grandson was considering reproducing the set-up.
I believe he built one and installed it in a car. The only big modification needed was that the front spring needed to have a special bend at one end to clear the offset differential housing.
Most of the differential parts were stock Ford, or modified T components. There was a video of a car with a Livingood set-up on YouTube. Not sure if it's still there.
Mike Spaziano.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Mar 03, 2025 11:56 am
I'm aware of the Livinggood setup. More complicated than it needs to be. Spring setup and all. It also has a few limitations which can be improved upon. In my humble opinion. Thanks for the info though.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Wed Mar 12, 2025 7:38 pm
Frame shortened 12 inches as well as driveshaft.
Aussie16
First Name: Warwick
Last Name: Landy
Post by Aussie16 » Thu Mar 13, 2025 7:14 am
What head are you running there Mark? It looks pretty chunky?
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Mar 13, 2025 10:16 am
The head is a cast iron original TURBO. I've only seen one other in my travels.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Wed Jul 30, 2025 8:22 pm
Moving right along!
Mark Chaffin
Last Name: Chaffin
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Wed Jul 30, 2025 9:02 pm
Nice work Mark! I really like the hood you are using.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Wed Jul 30, 2025 9:13 pm
That will be sweet and fun.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Jul 31, 2025 6:41 am
LOOKING GOOD THERE BIG DAWG!
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Aug 08, 2025 12:41 am
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Aug 08, 2025 12:43 am
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sat Aug 23, 2025 9:24 am
Installing cycle fenders and brackets.
Bills Auto Works
First Name: Bill
Last Name: Squires
Board Member Since: 2011
Post by Bills Auto Works » Sat Aug 23, 2025 12:50 pm
Hey Mark,
That thing is coming along nicely from when I was there a few months ago! I don't know whether to be happy for you that you are making major progress or sad for myself since I can't seem to make any on my stuff. LOL I guess both! :roll:
God Bless
Bill
https://www.jalopyjournal.com/forum/thr ... ed.614419/
Your QUALITY Model T Transporter in Business Since 1983 & Still Going Strong
57,64,66 Pont
(2)66 Amb
67 Marlin
67 Toro
73 Nova
(2)92 XJS
07 XLR-V
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sat Aug 23, 2025 5:17 pm
Thanks for the pictures mark, looking good.
Did you make the cycle guard mounting brackets? They are very neat and I am curious how they fit and how they are braced.
Would you mind sharing a few more details??
Thanks again
Adrian
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sat Aug 23, 2025 6:01 pm
Yes. The spindle brackets were made by hand. With two tabs welded on the plate to be mounted using the spindle arm. The spindle arm boss and nut were machined down 1/8" each to allow clearance. The rods are cold role steel threaded 1/2-20 at 4" Length for adjustment. The opposite end was turned down on a lathe to .425 for the fender eyelets. Once the brackets are attached to the spindle, a 1/4-20 short bolt was added front and rear to prevent the bracket from rotating. A few more pictures have been added to illustrate further.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sun Aug 24, 2025 3:35 am
Thank you, that is a clever solution! I will salt that idea away :-)
Cheers
Adrian
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sun Aug 24, 2025 11:50 am
Thanks Bill! For those in need of transportation, Bill is a true professional.
skyhunter
First Name: Donncha
Last Name: OapostropheMurchu
* REQUIRED* Type and Year of Model Ts owned: 1916 Speedster
Post by skyhunter » Sun Aug 24, 2025 12:15 pm
Nice! In New England they got a totally different idea of what a T doodlebug is, that would be a complete car here. 😂
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sun Aug 24, 2025 4:09 pm
I guess it pretty much is a complete car. Just 12" shorter. Since we're located in California, I can safely say, it identifies as a Doodlebug. Pronouns are Putt and Putt. :)
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Sun Aug 24, 2025 5:08 pm
Your going to beat me to paint Mark.
I'm still fixing errors from years ago, but I will finish this car.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sun Aug 24, 2025 8:20 pm
Still another month or so from paint. I did already purchase the John Deere green paint though. :)
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Sun Aug 24, 2025 10:26 pm
Explains the yeller wheels.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Tue Sep 02, 2025 6:27 pm
More progress. Almost ready for paint.
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Tue Sep 02, 2025 6:31 pm
Wow, a winch!
That must be a serious ranch!
Progress looks great Mark.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Tue Sep 02, 2025 8:00 pm
" Nothing runs like a dear Ford."
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Thu Sep 04, 2025 7:32 am
Mark, That is absolutely fantastic! Really like the fenders and the winch set up. Can't wait to see it in paint. Hats off to you sir!
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Sep 04, 2025 10:44 am
Fun making something different for a change.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Sat Sep 06, 2025 1:32 am
Good morning Mark,
Great project, I would like to see the finished produced.
Do you have photo of way you attached the rear fenders to the rear axle?
Andre
Belgium
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sat Sep 06, 2025 6:54 pm
Andrea. I'll take a few pics and add them on Monday.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Tue Sep 09, 2025 2:46 pm
AndreFordT
First Name: Andre
Post by AndreFordT » Tue Sep 09, 2025 4:30 pm
Thank You Mark.
Andre
Belgium
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Wed Sep 10, 2025 11:18 am
Mark. The Blockneys. Are they marked " Made in the UK."?
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Sep 11, 2025 7:25 pm
Made in Vietnam.
Post by Allan » Thu Sep 11, 2025 11:36 pm
Made in Viet Nam, to Blockley's own specifications. They have been supplying a large range of bias ply and vintage racing tyres for many years. They recognised there was a real quality problem with the quality of the tyres produced for our Ts, and set about rectifying this. What it needed was direction from the marketer for those better quality products. That better quality comes at a higher price, but as someone commented on the forum, if it leads to longer, better service, it is far better value over all.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Sep 12, 2025 10:24 am
My opinion. Far superior to the other offerings. Especially, their tubes.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Wed Oct 01, 2025 5:25 pm
All done with assembly. Time to taker her apart for paint!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Oct 02, 2025 3:32 am
LOOKING GOOD BIG DAWG!
AndreFordT
First Name: Andre
Post by AndreFordT » Sat Oct 04, 2025 7:03 am
I should just get satin clear coat to keep the rust aspect.
Andre
Belgium
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Sat Oct 04, 2025 9:14 am
I can't wait to see it in paint done. That is a awesome build!
Post by TRDxB2 » Sat Oct 04, 2025 12:07 pm
Where did you get the cycle fenders & what are the dimensions? Been looking to get some
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sat Oct 04, 2025 12:44 pm
I made them. About a 24" radius. Modified early fender brackets front and rear and attached with threaded rivits.
