oil temperature
Topic author - Posts: 145
- First Name: David
- Last Name: Kahle
- * REQUIRED* Type and Year of Model Ts owned: '26 coupe, '26 touring, ‘14 Staude tractor conversion, '27 coupe, '19 roadster, ’15 speedster, '14 touring
oil temperature
Does anyone know what the maximum oil temperature might be anticipated for a Model T? I'm still playing with rare earth magneto parts and 300 degrees F. seems to be the threshold temp. for neodymium.
- First Name: Jeffrey
- Last Name: Hausey
Re: oil temperature
If it gets above 230*f I would be greatly surprised.
Re: oil temperature
What you are doing has been done. Search in past posts.
- First Name: David
- Last Name: Kahle
Re: oil temperature
I have been fiddling with this for a few years and have made some very successful prototypes. They simply replace the original magnets with aluminum/rare earth pieces which lighten the flywheel about eight pounds and increase voltage by 30 to 40 percent with a mag gap of nearly 1/8 inch. Originally used samarium cobalt magnets which have a maximum operating temperature in excess of 550 degrees f. But are costly. High temperature neodymium magnets are far cheaper but have an operating threshold of just above 300 degrees.
