5 Ball Float and Seat
Rod
First Name: Rod
Last Name: Barrett
* REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
Board Member Since: 2014
Post by Rod » Thu Jan 15, 2026 2:37 pm
Since the passing of Stan and Russ does anyone have a source of valve seats and floats for the Kingston 5 Ball Carb?
The Stan Howe setup work great. The float is from a Harley Davidson.
The 1909 float and seat aren’t original. The problem is the seat is some sort of plastic ball and it hangs up.
Any source would be greatly appreciated.
Thanks,
Rod
Stan Howe setup
Stan Howe setup
1909 unknown vendor
1909 unknown vendor
Original
Original
Re: 5 Ball Float and Seat
Post by RajoRacer » Thu Jan 15, 2026 3:20 pm
Perhaps contact Corey Walker through here.
Last Name: Hatch
Post by Dan Hatch » Thu Jan 15, 2026 4:07 pm
Your unknown float picture looks like a JD float used years ago. I think I have some, look and try to o compare. Dan
Rod
First Name: Rod
Last Name: Barrett
Post by Rod » Thu Jan 15, 2026 4:25 pm
Dan,
The float in the 2nd picture of the 1909 Unknown is OK but the seat is sticking. It has some sort of plastic ball seat. Would you happen to have a different type in stock?
Please email me.
Thanks,
Rod
Last Name: Hatch
Post by Dan Hatch » Thu Jan 15, 2026 5:18 pm
Don’t know what the seat is. Grose jet????
I don’t have anything for. 5 ball.
In the olden days we put the JD float in to G carbs.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Thu Jan 15, 2026 5:33 pm
Contact Bill Glass. He has worked on my Kingston five ball carburetors with great success. I hope this help, Russ Furstnow
Rod
First Name: Rod
Last Name: Barrett
Post by Rod » Fri Jan 16, 2026 12:42 am
I found what looks like the sticking float needle seat.
https://www.modeltford.com/item/6212GJL2.aspx
I ordered it and hopefully it works.
Last Name: Hatch
Post by Dan Hatch » Fri Jan 16, 2026 3:11 am
Aka Grose jet float valve
Pat Branigan Wisc
Last Name: Branigan
* REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Post by Pat Branigan Wisc » Fri Jan 16, 2026 9:56 am
I've done a few 5 ball carbs and have used a brass float from an updraft carb on a cast iron Briggs and Stratton engine that fits quite well and bored the Kingston body and machined a Rochester 4 barrel seat and sweat it into the carb body and had to shorten the needle, A new hinge assembly with a screw adjustment for setting floor height worked very well.
RGould1910
Last Name: Gould
Post by RGould1910 » Fri Jan 16, 2026 11:26 am
I've made new floats for both 5 ball carbs and others using the closed cell material from Lang's without coating them. No issues to report after years of driving. I haven't had a leaking problem but still install a fuel shut off in line just in case. They're pretty easy to make on a lathe if you have a pattern.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Sat Jan 17, 2026 1:05 am
If you have that Grose jet in there then there should be 3/8”-24 threads there already, then you can get one of those 4-barrel needle and seats as previously mentioned here. You may have to shorten the threads and the top part for sure. Be sure and reform the needle so the little wire hooks on and the float going down can pull the needle up because the gravity feed has a hard time pushing it up sometimes.
You’ll have to make a float arm. I put those in 4-balls all the time, have to drill and tap. The distance is the same on the 5 ball from the seat to float hinge pin. The arm is a little longer but you have to make that anyway. I’ve made 5-ball floats from the material the vendors sell.
Rod
First Name: Rod
Last Name: Barrett
Post by Rod » Sat Jan 17, 2026 6:32 am
Can someone please post a link to purchase a “4-barrel needle and seat” as previously mentioned?
Thanks,
Rod
