What is this hole for? It has a pin in it for some reason.
Steering gear box
Re: Steering gear box
that's where the little screw that is always missing from the cover, fits into to keep the cover from unscrewing
http://www.mtfca.com/discus/messages/33 ... 1369460863
Moxie26
- Last Name: Jablonski
Top center of that steering box , is there a drilled hole? Normally that drilled hole would be threaded to accompany the steering box cover set screw to anchor the cover after tightening. Could be with yours, that the steering box was installed 180°off center...., And your set screw was broken off in the housing.
JBog
Topic author - Posts: 301
- First Name: Jason
- Last Name: Bogstie
Interesting! It does have a set screw at the top that hold the cap on.Moxie26 wrote: ↑Sat Oct 22, 2022 7:32 pmTop center of that steering box , is there a drilled hole? Normally that drilled hole would be threaded to accompany the steering box cover set screw to anchor the cover after tightening. Could be with yours, that the steering box was installed 180°off center...., And your set screw was broken off in the housing.
Usual repair to tighten up slop in top cover.
