Full Flow Float Valves™ for NH, Vaporizer and Simmons (Wizard) - Back in stock!
Topic author - Posts: 6557
Cures rips, tears, snares, corns, callouses, and beats back bad breath
not really
but it WILL make your car go up steep hills even with a low gas tank, and make "vapor lock" a thing of the past. You will never encounter a "9 gallon hill" again, with a float valve that REALLY FLOWS. If you're really unsure if they work, just ask the guy who just passed you on your next tour, or one of the many many Forum users who have already taken the plunge.
I am the designer, the manufacturer, and sole source for these valves. Beware of imitations.
As always, INQUIRE VIA EMAIL THROUGH THE MTFCA WEBSITE - NOT MESSAGING
QUESTIONS ALMOST ALWAYS RESPONDED TO THE SAME DAY
Thank you
not really
Thank you
- Last Name: Hatch
Re: Full Flow Float Valves™ for NH, Vaporizer and Simmons (Wizard) - Back in stock!
If you don’t have one in your NH, you better get one. Great product! Thanks for making it Scott.
- First Name: Henry
- Last Name: Lee
And just like that....., "The Grand Master of Micro Machining" pops out of his burrow to see if he is needed! Yes Scott your services are beyond needed and are a must! Rock On Brother!
The Recluse of "Dim Dar Hills in a Holler"
I haven't had luck with these valves. I wonder if the additives in the California gasoline has something to do with it?
Looks like itOriginal Smith wrote: ↑Mon Mar 03, 2025 12:51 pmI haven't had luck with these valves. I wonder if the additives in the California gasoline has something to do with it?
AI BOT
Specific gravity (SG) is a measurement of how dense an object or substance is compared to water, and it's used to determine if something will float or sink.
California gasoline typically has a slightly higher specific gravity compared to regular gasoline in other regions due to the mandatory addition of oxygenates like ethanol, which are slightly denser than the hydrocarbons in standard gasoline, resulting in a slightly heavier fuel mix; however, the overall difference in specific gravity is usually small and within the normal range for gasoline
Smith has never purchased any valves from me.
- First Name: Henry
- Last Name: Lee
Someone needs a bubble wrap re-enforced bandaid!
- First Name: Tom
- Last Name: Moorehead
I have two of these valves in straight thru NH carbs and they work flawlessly. No longer run out of gas on a hill unless the gas in the tank is stupidly low!
- First Name: Jamie
- Last Name: Maxwell
- * REQUIRED* Type and Year of Model Ts owned: 1919 touring
I'm having trouble getting an email or message to Scott Conger regarding ordering full flow float valve for an NH straight through model T carburetor - can anyone direct me ???
Jamie
your email came through and I have responded, so check your email
thank you
thank you
- First Name: Chris
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1926 fordor sedan,1927 fordor sedan. 1922 tourer, 1913 torpedo roadster pickup
- Board Member Since: 2014
Hi, how much each?, and could I have 4 please. And do you take paypal. Cheers
Chris Lawrence NZ
Chris Lawrence NZ
Chris
email sent to you
email sent to you
Unlike some folks, I will not bump this ad every other day. Every couple of weeks is fine.
Don't wait until the week before your summer tour. Get your car ready while the weather is still cool.
This ad is being bumped after 4 weeks of dormancy, hopefully is an example to folks who feel that bumping their own ad every 2 days and driving everyone else's out of sight is really clever. It really isn't. If folks want what you have, they'll find it and buy it, regardless of how often you pimp it.
See you in a few weeks or months
- First Name: Gerald
- Last Name: Robinson
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T Touring + 1923 Model T Touring
I'd be interested in purchasing two.
- First Name: TOM
- Last Name: LEROUX
- * REQUIRED* Type and Year of Model Ts owned: 1915 speedster-1927 pick up
SCOTT
i WILL TAKE THREE
TOM
i WILL TAKE THREE
TOM
Six week bump
not one week
not every other day
six weeks
last chance to be ready for the National Tours
not one week
not every other day
six weeks
- Last Name: Govoni
Scott,
I don't know if you did this before but is there a writeup somewhere that shows the difference in float valves and how they work? I've got a 26 so my tank is always above the carb. Some new guys may benefit from your expertise. Including me.
Robert
other than Dan Treace doing a write up of my valve in the club magazine a few years ago I know of no one who has ever done a comparison of valves. I can state with certainty, though, that every valve offered commercially (other than mine), has a through-hole that is sized for a modern car using a fuel pump. They are made by major manufacturers whose primary market is for modern cars, and our NH valve was simply an adaptation of every other valve they make (and they all need fuel pumps to operate properly).
My valve is specifically designed for the very low head pressure in a Model T, and the generally higher constant speeds that we run at.
As an example, here is a picture of a disassembled Grose Jet (valve) next to my valve and you'll see that the Grose Jet has a 25% smaller hole than mine which works out to nearly a 50% reduction of flow area. Every other valve has a similarly mis-proportioned body as well.
- Last Name: Govoni
Thanks so much Scott Now I know!!!! Thanks for all you do for the hobby.
- First Name: Brian
- Last Name: Mettling
- * REQUIRED* Type and Year of Model Ts owned: 1922 touring, 1933 Dodge
I got my set last week from Mr. C and put it on a fresh rebuilt NH center drain on my 22 touring. Much more pep and power!
