(SOLD) TT Truck Heavy Duty Rear Hub Puller with Strike Pin
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Thu Nov 20, 2025 12:01 pm
(SOLD) Thanks, Walt
namdc3
First Name: Nikolaus
Last Name: Martin
Re: FS: TT Truck Heavy Duty Rear Hub Puller with Strike Pin
Post by namdc3 » Thu Nov 20, 2025 10:51 pm
Is the thread 2-7/16”x16tpi? I have a puller like this, but I think it is 2-1/8”x24tpi, so T (or TT front).
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Thu Nov 20, 2025 11:11 pm
Yes, thread size is 2-7/16 x16. Information added to above ad. Thanks, Walt
namdc3
Last Name: Martin
Post by namdc3 » Fri Nov 21, 2025 8:41 am
That’s really interesting. Thank you. I went out and looked at mine, and it is model T size. I noticed that mine is thicker between the threads and the outer diameter of the puller. I think that they must have used the same casting or forging and machined them differently.
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Fri Nov 21, 2025 10:05 am
Yes, they made this type of heavy duty puller with the strike pin for both T's and TT's. I have had both in the past.
