(SOLD) TT Truck Heavy Duty Rear Hub Puller with Strike Pin
WaltM
Topic author - Posts: 325
- First Name: Walter
- Last Name: Magas
(SOLD) Thanks, Walt
namdc3
- First Name: Nikolaus
- Last Name: Martin
Re: FS: TT Truck Heavy Duty Rear Hub Puller with Strike Pin
Is the thread 2-7/16”x16tpi? I have a puller like this, but I think it is 2-1/8”x24tpi, so T (or TT front).
WaltM
- Last Name: Magas
Yes, thread size is 2-7/16 x16. Information added to above ad. Thanks, Walt
namdc3
- Last Name: Martin
That’s really interesting. Thank you. I went out and looked at mine, and it is model T size. I noticed that mine is thicker between the threads and the outer diameter of the puller. I think that they must have used the same casting or forging and machined them differently.
WaltM
- Last Name: Magas
Yes, they made this type of heavy duty puller with the strike pin for both T's and TT's. I have had both in the past.
