Deleted add
WaltM
First Name: Walter
Last Name: Magas
Deleted add
Post by WaltM » Wed Nov 01, 2023 4:50 pm
Deleted add
WaltM
First Name: Walter
Last Name: Magas
Re: Wanted Three Rajo Rocker Arms and Valve Cover
Post by WaltM » Fri Nov 03, 2023 9:44 am
to the top
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Mon Nov 06, 2023 11:37 am
Back to top
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Mon Nov 06, 2023 2:54 pm
Walt, I can’t help you with any extra rocker arms for a Rajo Model 30 commercial head, but a few years ago I was able to buy a rocker arm cover for a Model 30 head from Dan McEachern . The only difference in the commercial head cover is that the commercial head has a shelf for short head bolts on the valve port side , their for the cover doesn’t need to clear a head bolt. A standard Rajo cover will work if don’t mind another place to leak rocker oil from the felt pad.
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Tue Nov 07, 2023 7:33 am
Kevin, thank you for your reply and information. I will follow up with your lead. Thanks again, Walt
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Tue Dec 26, 2023 1:57 pm
To the top
WaltM
First Name: Walter
Last Name: Magas
Re: Wanted Three Rajo Rocker Arms Model 30
Post by WaltM » Fri Jan 05, 2024 4:44 pm
Looking for Rajo rocker arm to match the ones in the photos. Thanks, Walt
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Sun Jan 07, 2024 6:15 pm
To the top
Southfork Creek
Last Name: Wightman
Post by Southfork Creek » Mon Jan 08, 2024 4:39 pm
If you are tired of waiting for an original, try Rocker Arms Unlimited in California, phone 530-242-1316, website www.rockerarms.com
They built a set for my Rajo C35. If you have one to send them, then likely you will be in good shape.
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Thu Jan 25, 2024 2:50 pm
to the top
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Thu Feb 01, 2024 2:11 pm
To the top
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Mon Feb 19, 2024 12:22 pm
to the top
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Tue Feb 27, 2024 2:02 pm
Still Looking for three original rocker arms.
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Fri Mar 15, 2024 12:42 pm
Back to the top. Thanks, Walt
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Tue Mar 26, 2024 3:54 pm
Still looking, Thanks, Walt
