Deleted add
				kmatt2
- First Name: Kevin
- Last Name: Matthiesen
Re: Wanted Three Rajo Rocker Arms and Valve Cover
Walt,  I can’t help you with any extra rocker arms for a Rajo Model 30  commercial head, but a few years ago I was able to buy a rocker arm cover for a Model 30 head from Dan McEachern . The only difference in the commercial head cover is that the commercial head has a shelf for short head bolts on the valve port side , their for the cover doesn’t need to clear a head bolt. A standard Rajo cover will work if don’t mind another place to leak rocker oil from the felt pad.
				WaltM
- First Name: Walter
- Last Name: Magas
Kevin, thank you  for your reply and information. I will follow up with your lead. Thanks again, Walt
				WaltM
- Last Name: Magas
Re: Wanted Three Rajo Rocker Arms Model 30
Looking for Rajo rocker arm to match the ones in the photos. Thanks, Walt
				WaltM
- Last Name: Magas
To the top
				Southfork Creek
- Last Name: Wightman
If you are tired of waiting for an original, try Rocker Arms Unlimited in California, phone 530-242-1316, website www.rockerarms.com
They built a set for my Rajo C35. If you have one to send them, then likely you will be in good shape.
				WaltM
- Last Name: Magas
to the top
				WaltM
- Last Name: Magas
To the top
				WaltM
- Last Name: Magas
to the top
				WaltM
- Last Name: Magas
Still Looking for three original rocker arms.
				WaltM
- Last Name: Magas
Back to the top. Thanks, Walt
				WaltM
- Last Name: Magas
Still looking, Thanks, Walt
