JUST THINK WHAT YOUR DOING,
Topic author - Posts: 353
- Last Name: Grzegorowicz
I NEEDED TO REPLACE THE NEEDLE VALVE AND SEAT IN MY KINGSTON L-4, 1921 CARB, WHEN I PUT THE SCREW DRIVER IN THE SLOT, FIGURING THIS HAS BEEN IN THERE CLOSE TO A HUNDRED YEARS, THOUGHT ABOUT THE HANDS THAT PUT IT THERE, I STOOD THERE A MOMENT THINKING A HUNDRED YEARS AGO THAT PERSON WAS MAKING 5 DOLLARS A DAY, HOW MANY OF THOSE VALVES DID HE DO IN A DAY, WHO WAS HE .THANK YOU SIR, BECAUSE THAT SEAT CAME RIGHT OUT LIKE IT WAS PUT THERE YESTERDAY.AND NOT A MARK ON IT, IT JUST WOULD NOT HOLD BACK THE GAS OVER NIGHT ANY MORE.I PERHAPS COULD HAVE GROUND IN A NEW SEAT BUT LANG'S IS SENDING ME NEW GASKETS AND VALVE, I WONDER HOW LONG THE REPLACEMENT WILL LAST. AND I BET THE NEXT HANDS TO DO THIS OVER WONT GIVE IT A SECOND THOUGHT. THE WORN PART WILL BE MARKED AND PUT IN THE SPARE PARTS BOX TO BE FOUND AT A LATER TIME,PERHAPS WHEN PARTS LIKE LHIS ARE NO LONGER AVAILABLE,
Re: JUST THINK WHAT YOUR DOING,
You had better go buy a lottery ticket if your luck is that good. Those seats can be pretty stubborn with just a screwdriver.
THIS IS WHAT I DID RICH, I TOOK A OLD BIG SCREW DRIVER GROUND THE TIP TO FIT SNUG AND VICE GRIPS FOR LEVERAGE ,THE HARD PART WAS HO TO HOLD THE BODY AS NOT TO BEND SOMETHING. YES I WAS LUCKY.
