Mag Ring Casting Number?
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Jun 23, 2020 10:50 am
What is the casting number on the late mag ring, used until the end of production?
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Re: Mag Ring Casting Number?
Post by R.V.Anderson » Tue Jun 23, 2020 2:39 pm
T-4389 is the factory number for the last version of the cast iron frame that had a starter notch and used 3/16" copper. It first appeared in April 1921 and was used to the end of production.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Jun 24, 2020 11:29 pm
Thanks, R. V. . I'm looking at a mag ring from a Canadian engine. It has the starter cut out and single stack coils but I don't know the original wire thickness. As best I can make out, the casting number looks to be T 5932 B . Any Canadian T owners: are canadian T casting numbers THAT far off from USA numbers. I may not be reading the casting number correctly; number is hard to read.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Thu Jun 25, 2020 10:23 am
As far as I have been able to tell from having rewound many thousands of field coils, all mag frames that have "Made in Canada" cast into them used the 3/16" copper. Further, on all of them, the height of the poles is considerably shorter than on US-made frames, so in rebuilding one of those you have got to be extra careful as there is very little leeway available to you in the finished height of the individual windings.
