1926 Model T sediment bowl
jimuris
Topic author - Posts: 24
- Last Name: Pakuris
- * REQUIRED* Type and Year of Model Ts owned: 14,24 TOURING 15 OPEN EXPRESS
Quick question, on the 26 sediment bowl the valve should face down to get the flow of fuel. There is a little hole inside on the shaft and that should face down correct.
bobt
- First Name: Robert
- Last Name: Thompson
Re: 1926 Model T sediment bowl
Valve handle pointing down is on. Pull the valve handle up 1/4 turn is off. Also, there is a strainer screen inside the potato. DO NOT put a paper filter in the sediment bowl. bobt
The valve handle should point down, however, it is possible to install the handle 180 degrees and have the handle point up when on. So if you get no fuel with the handle pointing down, try pointing up. If neither will allow fuel to flow, you have a blockage elsewhere in the fuel system.
