Evening all,
I recently picked up this wrench. It looked familiar so I grabbed it. From some searching it appears to be the 1910 T1349 wrench. I just want to double check.
Curious too, as to value? I dont really ask that question, but I think these are hard to find. Im always looking to supplement my 1913s fund if I can.
Benji
Is this a 1910 T1349 Hub Wrench?
- First Name: Susanne
- Last Name: Rohner
Re: Is this a 1910 T1349 Hub Wrench?
I thought I knew what I was talking about, but apparently I was way off, so I'm deleting this post...
I found this on page 655 in the encyclopedia. Not a perfect match, but awfully close.
I didn't want to reply when I first read the OP, because I am not a tool expert. But I don't think I have ever heard of Weston Mott supplying to Ford. It would anyway be great for someone with an early T wanting to have a "proper" tool kit, but not looking for maximum points in judging. You should make sure the hubcap and bearing nut ends properly fit the designated items. Similar wrenches were used on a number of other cars. Weston Mott supplied front and rear axle assemblies to many marques. Buick was one of the largest users of their axles.
- First Name: Charles
- Last Name: Little
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1924 Del. Truck, 1924 Touring
The short answer is: Yes, this is what was supplied with the early cars.
http://www.mtfca.com/discus/messages/41 ... 1412295482
Charlie Little, South Paris, Maine
- Last Name: Little
The are found unmarked, and marked by 3 makers; Hayes, Prudden and Weston Mott.
.http://www.mtfca.com/discus/messages/17 ... 1304804666
