window lift straps
Gene
Topic author - Posts: 10
- First Name: Condon
- Last Name: Story
- * REQUIRED* Type and Year of Model Ts owned: 1911 torpedo 1916 tractor conversion 1922 roadster 1923 hack 1926 4 door 1926 1 ton truck
window lift straps
How do you hook the lift strap to the window on a 1 ton TT truck, or is it hooked some other way?
One390
- * REQUIRED* Type and Year of Model Ts owned: 25 TT
Re: window lift straps
Gene
Try these threads. I used an old window lift channel and made the rod and mount by cutting, bending and welding a little rod to attach the strap. You have to fool with length so the window is up in the last hole. Wasn’t too bad of a job if I recall. Others can suggest what to use to keep the glass in the channel.
http://www.mtfca.com/discus/messages/11 ... 1287772854
http://www.mtfca.com/discus/messages/29 ... 1204327449
