Stewart 1276 speedo disassembly
pons0030
First Name: Melchior
Last Name: Pons
* REQUIRED* Type and Year of Model Ts owned: 1916 speedster
Post by pons0030 » Wed Feb 27, 2019 10:24 am
I like to restore my Stewart 1276 speedometer.
However, I cannot take it apart. I am just able to unscrew the back and a chrome ring but that is blocked by the dat counter reset knob. I don’t want to break anything.
Does have anyone experience with this?
Re: Stewart 1276 speedo disassembly
Post by Original Smith » Wed Feb 27, 2019 9:40 pm
What is a Stewart 1276 speedometer? Post a picture!
pons0030
Last Name: Pons
Post by pons0030 » Thu Feb 28, 2019 3:18 am
I tried to post a picture yesterday. I will check the instructions. I did find a link to a photo, I hope that works for now:
http://www.2040-parts.com/vintage-antiq ... -i1487111/
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Post by Russ_Furstnow » Thu Feb 28, 2019 8:28 am
The 1276 number is stamped into the back of the cupped bracket that holds the speedometer to a steel dashboard. The 1276 number is a prt number for the cupped bracket. The speedometer in the photo is a Stewart Warner Model 131, which is identical to a Model 160. I hope this helps,
Russ Furstnow
AdminJeff
Post by AdminJeff » Thu Feb 28, 2019 8:30 am
I just had mine apart not log ago to “fix” it... it came apart easily as I recall. Lot’s of little bits inside but easy to deal with. A good cleaning and a little Hammond B3 oil on the gears and now it works great and is surprisingly accurate.
pons0030
Last Name: Pons
Post by pons0030 » Tue Apr 02, 2019 6:49 am
Thanks Russ, I did not know that about the casing/bracket.
Mel
