Model T Ranch #1075 Slipping clutch fix kit
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Sun Jan 24, 2021 10:29 am
Just saw this on tbay, what in the world is it and how does it work. Must be magic if it will fix a slipping clutch that has no adjustment left..............
Re: Model T Ranch #1075 Slipping clutch fix kit
Post by Mark Gregush » Sun Jan 24, 2021 10:33 am
Jim how about a link?
Jim Eubanks
First Name: Jim
Last Name: Eubanks
Post by Jim Eubanks » Sun Jan 24, 2021 10:55 am
TBAY item number: 265025143764
Post by TRDxB2 » Sun Jan 24, 2021 11:55 am
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sun Jan 24, 2021 12:03 pm
I hope they supply instructions with it. Just from the pictures, looks like 'snake oil' to me.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Jan 24, 2021 12:31 pm
So it would appear to be a “spacer” that can be installed to increase the spring pressure.
Perhaps I’m not understanding it correctly though.
Post by Mark Gregush » Sun Jan 24, 2021 12:38 pm
If it is snake oil, it has been around for a while. Sometimes it is worth reading that catalogs to know what is out there.
https://www.modeltford.com/item/3340SP.aspx
Post by John kuehn » Mon Jan 25, 2021 8:25 am
Makes sense it would work. Adding a shim ‘so to speak’ to add tension to the spring.
Beats having to going through the hassle of changing the spring.
Post by Jerry VanOoteghem » Mon Jan 25, 2021 3:38 pm
I'd be scared to death that gadget would come loose and make all kinds of trouble. :shock:
