Ford Part Puzzle No. 3
Topic author - Posts: 3950
Another part puzzle to solve, takes some thinking!
Re: Ford Part Puzzle No. 3
It looks like the washer that is used on the 1921-27 mufflers to help hold the rear shell on.
- First Name: Adam
- Last Name: Doleshal
A washer from a windshield frame adjuster
I went out and looked at the original muffler that come off my 21. It is the style that the pipe goes thru and is the inner baffle. The washer on it is cupped, the outer edge presses on the rear cap. 1-1/4 in diameter, 3/8 hole, about 1/8 thick. The stud it mounts on is 5/16. The question does not say what material it is made from, but the windshield washers I have seen were brass with slots 90 degrees to each other.
https://www.modeltford.com/item/7818N.aspx
Too big to be the muffler end washer, a HINT is given in the original ?.....that is two repairmen each found this washer taking two separate engines apart...read that carefully
. BTY the washer is steel.
Keep on thinking....that thin tapered edge washer got into these engines somehow.
Another Hint....that little tapered washer got sucked up the intake, so anyone know where it originated?
- First Name: Phil
- Last Name: Mino
From Bruce's book, page 564:
DEC 20 (1922) (Engine production records)
"Began using 3/8" washer at #4 manifold stud to keep
from bending hot air pipe."
Phil
That would be a regular washer, used to prevent the flaring of the ears on the early series of hot air pipe.
The crowned or domed- shaped washer in question is wafer-thin tapered to the edge, unlike any standard washer. .....
Another hint....that little washer is found on a supplied Ford part.
A standard washer helps to prevent this:
I'll stick by my observation. I've got several of those washers, and they were used on the muffler at the rear!
Larry
Agree that the little thin tapered to the edges domed shaped washer in question might look like in the sketch as a muffler end plate washer behind the nut holding the muffler together, but is not that washer.
Do you suppose a muffler end plate washer could be found inside an engine?
This puzzle is rather extremely difficult, as the author of these Questions, Murray Fahnestock didn't immediately know the answer.
And this little washer part was later deleted......
- First Name: Art
- Last Name: McTevia
- * REQUIRED* Type and Year of Model Ts owned: 1924 Runabout
Maybe a button off of Steve Jelfs coveralls
- First Name: Edward
- Last Name: Baudoux
Art, Steve isn't quite That old
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
- First Name: Douglas
- Last Name: Keppler
Dan was there a puzzle #2?, cant find that one
1924 Touring car
There's No Substitute for Proper Lubrication
- First Name: Adam
It’s the washer that goes under the nuts on the outside of the firewall for ‘26-‘27 cowl mounted fuel tank straps.
Good call, Adam - I don't have any T's that new !
- First Name: George P
- Last Name: Clipner
I'm going with Adams observation. Cowl Tank mounting strap washer. Replaced mine couple of years ago .
I suppose you could use it on the end of a muffler too.
Doug
Puzzle # 2 is here:
viewtopic.php?f=2&t=1986
No. 1 was in original post by Steve J. "Was this ever a Ford Part"
As for the suggestions to date, still an un-solved mystery!
New HINT.
Think about how a small tapered washer could be sucked up the intake.
What major supplier Ford part is attached to the intake manifold?
Final HINT.
Wondering if Stan Howe has been viewing this thread? His experiences would solve this mystery!
I'll post the answer tomorrow prior to trucking to Chickasha!
Puzzle # 2 is here:
New HINT.
Final HINT.
The Reveal...here’s the mystery of the little thin washer.
Hint was attachments to intake manifold and what major supplier.
The carburetor and a major supplier was Kingston.
Seems the Kingston is famous for the flapper and that little washer was part of the flapper assembly.
Some owners from 1915 to 1919 had these troubles as the flapper assembly came apart in the Kingston L and L2. Later ones and the L4 used a revised flapper assembly to prevent this occurrence. So if you are experiencing poor running of your early L or L2 maybe the old style flapper assembly is the cause
And now for the next question: How many rebuilt Kingston carburetors get a new fiber washer on the flapper?
Answer: Not many
Answer: Not many
