Any trick to getting this off?
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sun Oct 17, 2021 3:01 pm
So I'm trying to fit some wood in place and I see that I have to take off the big nut and top Iron support stud.
This is the nut.
Is there a way to hold this stud without having to use vice grips? I don't want to chew it all up.
Re: Any trick to getting this off?
Post by Scott_Conger » Sun Oct 17, 2021 3:08 pm
Double nut it, perhaps with thin jam nuts, and that will act as a head on a bolt and things can be taken apart
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Sun Oct 17, 2021 3:09 pm
Remove the cap then do a double nut on the threads. Give you something to hang on to.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sun Oct 17, 2021 3:27 pm
OK now I feel dumb. Thanks!!!!!!
Post by Mark Gregush » Sun Oct 17, 2021 3:31 pm
If it was painted in place, suggest scoring the pant around where it meets the body so does not pull or chip the surrounding paint.
Post by Scott_Conger » Sun Oct 17, 2021 5:54 pm
or simply saw a clearance slot into the back and slid it over/past the nut. No one will see it and it will still function fine as a tack strip
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sun Oct 17, 2021 7:13 pm
Well that worked. I used two nuts and it came right out. Then I showed my daughter that mechanical trickery.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Sun Oct 17, 2021 8:49 pm
It’s amazing all the trickerization you can learn here. Ha
Mopar_man
Last Name: Govoni
Post by Mopar_man » Sun Oct 17, 2021 8:53 pm
I've been passing on all your tricks to my 16 year old.
