Emergency Brake
AndreFordT
First Name: Andre
Last Name: Valkenaers
* REQUIRED* Type and Year of Model Ts owned: 1926 ; 1922 ; 1915.
Emergency Brake
Post by AndreFordT » Wed Oct 20, 2021 12:19 am
Just need to repair the emergency brakes on a 1912 right hand drive (English) Touring.
Here is what I found. Watch the setup. It is strange. Was it after market? Or did someone a special build for this car?
I think it will end with a total rear axle rebuild. I found also left - right play on the shafts.
Andre
Belgium
Craig Leach
First Name: craig
Last Name: leach
Re: Emergency Brake
Post by Craig Leach » Wed Oct 20, 2021 1:05 am
Andre.
Those are a aftermarket part designed to be adjustable from the outside by taking up the wedge instead of adjusting the brake rod keeping the propper lever angle. Judging by the silver metalic color of the grease your thrust babbitts have become liquid or you lost a bearing. I would suggest you replace the park brake linings, its near impossible to get the grease out of them. Good luck.
Craig.
AndreFordT
First Name: Andre
Re: Emergency Brake
Post by AndreFordT » Wed Oct 20, 2021 10:24 am
Craig,
I ordered at Langs a total brake rebuild kit.
Due to the play on the shafts and the grey color of the rear axle oil, I will take the rear axle apart for a total rebuild. Not cheap but the only way to do it right and keep the oil and grease off the brakes and leaking on the wheels.
Andre
Belgium
Re: Emergency Brake
Post by Steve Jelf » Wed Oct 20, 2021 11:06 am
I recently learned that inner axle seals should be installed with gear oil RTV. Other sealants are likely to leak.
John.Zibell
Last Name: Zibell
Re: Emergency Brake
Post by John.Zibell » Wed Oct 20, 2021 11:11 am
Steve, that sealant is great for the housing and spool, but not so great for the modern inner seal as it doesn't adhere and harden. Ultra black seems to do better for the modern inner seal.
1926 Tudor
Re: Emergency Brake
Post by Steve Jelf » Wed Oct 20, 2021 10:37 pm
Well, now I don't know what to think. Stephen Heatherly told me that the gear oil sealant cured his leaking seals, while Ultra Black hasn't stopped mine.
Art M
First Name: Art
Last Name: Mirtes
Re: Emergency Brake
Post by Art M » Wed Oct 20, 2021 11:09 pm
In addition to the 2 seals on each side, I add another seal, which is altered, outboard of the inner bearing sleeve. The seal modification involves a notch cut into the OD of the seal. The notch is oriented so that is in the bottom position. This seal serves as a labyrinth. The notch allows any oil that gets past this seal to flow back to the center of the differential. I found that oil generally follows the OD of a rotating shaft.
After 3200 miles, my brakes are still dry.
Art Mirtes
