Emergency Brake
AndreFordT
Topic author - Posts: 532
- First Name: Andre
- Last Name: Valkenaers
Emergency Brake
Just need to repair the emergency brakes on a 1912 right hand drive (English) Touring.
Here is what I found. Watch the setup. It is strange. Was it after market? Or did someone a special build for this car?
I think it will end with a total rear axle rebuild. I found also left - right play on the shafts.
Andre
Belgium
Andre
Belgium
- First Name: craig
- Last Name: leach
Re: Emergency Brake
Andre.
Those are a aftermarket part designed to be adjustable from the outside by taking up the wedge instead of adjusting the brake rod keeping the propper lever angle. Judging by the silver metalic color of the grease your thrust babbitts have become liquid or you lost a bearing. I would suggest you replace the park brake linings, its near impossible to get the grease out of them. Good luck.
AndreFordT
- First Name: Andre
Re: Emergency Brake
Craig,
I ordered at Langs a total brake rebuild kit.
Due to the play on the shafts and the grey color of the rear axle oil, I will take the rear axle apart for a total rebuild. Not cheap but the only way to do it right and keep the oil and grease off the brakes and leaking on the wheels.
Andre
Belgium
Andre
Belgium
Re: Emergency Brake
I recently learned that inner axle seals should be installed with gear oil RTV. Other sealants are likely to leak.
John.Zibell
- Last Name: Zibell
Re: Emergency Brake
Steve, that sealant is great for the housing and spool, but not so great for the modern inner seal as it doesn't adhere and harden. Ultra black seems to do better for the modern inner seal.Steve Jelf wrote: ↑Wed Oct 20, 2021 11:06 amI recently learned that inner axle seals should be installed with gear oil RTV. Other sealants are likely to leak.
1926 Tudor
Re: Emergency Brake
Well, now I don't know what to think. Stephen Heatherly told me that the gear oil sealant cured his leaking seals, while Ultra Black hasn't stopped mine.
Art M
- First Name: Art
- Last Name: Mirtes
Re: Emergency Brake
In addition to the 2 seals on each side, I add another seal, which is altered, outboard of the inner bearing sleeve. The seal modification involves a notch cut into the OD of the seal. The notch is oriented so that is in the bottom position. This seal serves as a labyrinth. The notch allows any oil that gets past this seal to flow back to the center of the differential. I found that oil generally follows the OD of a rotating shaft.
After 3200 miles, my brakes are still dry.
Art Mirtes
Art Mirtes
