Which years does this spark coil fit?
Last Name: Patrick
Post by jiminbartow » Sat Feb 19, 2022 5:55 pm
Good evening. What years does this size spark coil fit? I know it fits the 1926 and ‘27, but I’m not sure of the other years it fits. If I’m not mistaken, the earlier years used a different size. Thank you for your help. Jim Patrick
Re: Which years does this spark coil fit?
Post by Norman Kling » Sat Feb 19, 2022 6:05 pm
I don't know the exact year for that particular coil, but it is a standard Ford coil and It will fit a 20, 22, 25 and 26. So I suspect that all the years between those will fit also. Don't know whether it will fit the Brass era T's.
Last Name: House
Post by George House » Sat Feb 19, 2022 6:29 pm
Nice clear, vibrant close-up pictures. It’ll ‘fit’ in a 14-16 coil box but wouldn’t be correct. Otherwise, it’ll fit and be correct for all 17-27 Model T s.
Last Name: Patrick
Post by jiminbartow » Sat Feb 19, 2022 6:31 pm
Thank you. Yes. It is standard. It came out of my ‘26 coupe… So, it will fit the 1920,‘21,‘22,‘23,’24,’25,’26 and 1927, but not the 1919 and earlier? Thank you. Jim Patrick
Kerry
Last Name: van Ekeren
Post by Kerry » Sat Feb 19, 2022 6:33 pm
It will fit as far back as early year of 1913
Last Name: Patrick
Post by jiminbartow » Sat Feb 19, 2022 6:38 pm
I just checked Lang’s online catalog and it said this coil would fit 1914-1927. If I put that in my description, would it be wrong or misleading? Would this coil work in a 1914, 1915 and 1916? Thank you all very much. I just need to get this right, for sure. Jim Patrick
Post by RajoRacer » Sat Feb 19, 2022 6:41 pm
Brass top coils are correct for '14 - '16 - in that neighborhood, although that one does fit.
Last Name: House
Post by George House » Sat Feb 19, 2022 6:45 pm
Yes Jim. As I stated at 5:29 pm today, it’ll fit and work in a 14-16 coil box too. Correct for 17-27.
Post by Wayne Sheldon » Sat Feb 19, 2022 7:08 pm
Hey there Jim P!
Early brass Ts used a variety of manufacturers, and they changed models and dimensions a few times. For 1913, Ford decided to standardize the coil design and fit. The actual change was made about mid model year for 1913, or about May of 1913. Many earlier model Ts had their coil boxes changed to the new style for reliability and maintenance reasons.
Properly stated, it "fits and works originally from mid 1913 through 1927 model T Fords." It "fits and is authentically correct for 1918 through 1927 model T Fords."
The technicality is that mid 1913 through 1916 model T Fords used brass/copper topped coils (some of which were coated in a black oxide originally!). And many 1917s used an odd black experimental plastic case that didn't work out very well. Most of those experimental plastic coils warped and began failing quickly. Ford discontinued them before 1917 was over, and went to the all wooden coil like you have. People wanting to "properly" restore their 1913 through 1917 model T may choose to insist upon either the brass/copper top or the odd plastic coils as a special detail. People wanting a driver T usually don't care and cover the coils with the box's lid anyway. So the top of the coils can't be seen anyway. And the later wood-topped coils fit and work perfectly in the mid 1913 and later brass era coil boxes.
Good luck Jim!
Last Name: Patrick
Post by jiminbartow » Sat Feb 19, 2022 7:29 pm
Thank you, all. So my description should say. “These coils will work in the later 1913 thru 1927 Model T’s, however they are correct for 1917 thru 1927 Model T’s. While they will work in 1913 thru 1916, they are incorrect in appearance than the ones that were designed for the 1913 thru 1916 Model T’s.” Do you think that is accurate enough? Please critique. Thank you, again. Jim Patrick
Kerry
Post by Kerry » Sat Feb 19, 2022 7:39 pm
It is correct when talking calendar years but in Model years, Fiscal years, then 1914 and on. seems to be a lot of research and time invested for the sale of a $10 part. :D
Last Name: House
Post by George House » Sat Feb 19, 2022 7:42 pm
You got it Jim. Your last post is entirely correct.
Last Name: Patrick
Post by jiminbartow » Sat Feb 19, 2022 8:28 pm
Thank you everyone for all your help. I feel comfortable that there will be no deceit or misunderstandings. Jim Patrick.
Post by Norman Kling » Sat Feb 19, 2022 10:16 pm
Are you selling your T's? It is always good to have some spare coils on hand and even keep one or two in each of your cars just in case you have a problem with a coil on a tour. Or you might be able to help another driver who has a problem
DickC
First Name: Dick
Last Name: Cruickshank
Post by DickC » Sun Feb 20, 2022 7:23 am
I can be corrected but the modification to coils by Henry was not "plastic" but made of a mixture of "soy bean". They did not last and he returned to the common wood design. Dick C.
VowellArt
First Name: Martynn
Last Name: Vowell
Board Member Since: 2012
Post by VowellArt » Sun Feb 20, 2022 8:31 am
17-27
Fun never quits!
Ron Patterson
Post by Ron Patterson » Sun Feb 20, 2022 10:22 am
The specific coil depicted in your photos is typical of the "standard" size (non metal top) coil adopted for the Model T mid year 1917 and can be used in the metal coilbox that was introduced in mid year 1913 and used till thge end of Model T production.
The "standard" size all wood and metal top coil are interchangeable in any metal coilbox with the exception that metal top coils (1913 to mid year 1917) should not be used in the 1926-27 metal coilbox. The the coilbox lid spring tabs that securely hold the coils in place inside the coilbox will interfere with the raised metal stamping. The tabs will distort and can short the coil points to ground.
A few comments about the specific coil pictured above. After the Wheat gluten cast design was withdrawn and the standard all wood was adopted there was a short time when coils made by Ford had no Ford script. The branded Ford script showing first appeared in 1919 (I have forgotten the exact date) and was changed to the rolled in script on the top edge of the wood case top in February 1923 and remained unchaged till the end of Model T production.
Ron Patterson
Last Name: Patrick
Post by jiminbartow » Sun Feb 20, 2022 11:10 am
Thank you everyone. This has been a very interesting and informative thread. Norman…. Since you asked, yes I am selling my Model T’s. There seem to be so many here that, for some reason, frown on anyone mentioning that he has Model T items for sale, when such notifications should be welcome to our members when some parts are becoming so hard to get, I have avoided mentioning it. Since September, I have been selling all of my spare T parts and have had the Red ‘26 Fordor listed, which I think I have sold to a fellow in Texas for $8,500.00, who plans to fly to Florida in March to pay me and transport it to its new home and I am getting my ‘26 coupe all polished up, tuned up and ready to list in the coming weeks. It has never looked better. As much as I love Model T’s, I seem to have lost my passion for the hobby and with six rental properties and mowing to maintain, I just don’t have the time for it. Also, at 68 years of age, I’m not getting any younger, in addition to the fact that, last October, my best lifelong friend I joined the Marine Corps with, died of a stroke. In addition to this, there are the many MTFCA members that have met with sudden, untimely and premature deaths, that has demonstrated to me that we are all mortal and death can overtake us at any time. My mortality has become apparent and if anything were to happen to me, my wife would be lost as to how to deal with all of the valuable items I have accumulated over the past 50 years. Since September, I have sold over a hundred items on eBay for over $50,000.00, after getting paid for the Fordor, over $60,000.00. Overall, I have made much more than what I paid. After my Dad’s death in 2017, we sold his entire estate, accumulated over 70 years, in an estate sale and came away with just $4,000.00. I was amazed at how little the stuff sold for, for he only bought the finest quality. Judging by the true value of what I felt his estate was worth, $4,000.00 is less than half a penny on the dollar and the estate liquidators got more than my sister and I. I think it is better the way I am doing it. As hard as it is, the hardest will be selling my ‘26 coupe that I restored in 1970 and have had for 52 years, but I need to be sure it goes to a good home. Preferably the home of a Model T lover that will love it and keep it up as I have. Bittersweet, but necessary for my wife and I. Jim Patrick
Post by Original Smith » Sun Feb 20, 2022 11:29 am
I have seen examples of later coils with the Ford script at the top, and in the center.
Matt in California
First Name: Matt
Last Name: G
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
Post by Matt in California » Sun Feb 20, 2022 12:59 pm
Martynn,
Great drawing! I think it is the first time I noticed it.
Everyone, the best document I came across regarding Ford coils is The Model T Ignition Coil by Trent Boggess and Ronald Patterson. I understand it was originally in the Vintage Ford. Then I think it was available at a vendors website. But I could only find it here: https://studylib.net/doc/8191195/the-mo ... ition-coil.
In this Forty pages of information you will see the coil in question is listed as a 1919-1923.
I believe this document should be put as a resource document on the MTFCA.
Enjoy,
Matt
Post by Steve Jelf » Sun Feb 20, 2022 1:48 pm
I don't find the Boggess-Patterson article in the MTFCA abridged online version of Bruce's encyclopedia, but it is in the full version available on flash drive.
VowellArt
First Name: Martynn
Last Name: Vowell
Post by VowellArt » Sun Feb 20, 2022 7:28 pm
Um Matt, all my drawings are here on the Forum under MTFCA.com/Resources/Drawings or from the forum page in Gallery/VowellArt and are free to all members to use or download. So, if you need to look for something for your car, there's a good chance you'll find it there...but I've still got a few other assemblies to go before I can finally get to that damned big, heavy, noisy, thing up front, which will complete the chassis. ;)
Fun never quits!
