26 t front body to frame mount missing
Dave Foley
First Name: David
Last Name: Foley
* REQUIRED* Type and Year of Model Ts owned: 26 touring 26 roadster
Post by Dave Foley » Fri Mar 11, 2022 1:43 pm
front body to frame mounts were removed does anyone have replacements or a drawing to fabricate from? Thanks for your help
Re: 26 t front body to frame mount missing
Post by DanTreace » Fri Mar 11, 2022 2:07 pm
Haven't a drawing or part replacement, but here is a pic of what that front frame mount looks like.
Post by Norman Kling » Fri Mar 11, 2022 5:03 pm
Do you have one on the other side? You might need to make one mirror image of the other. Those are usually ok and attached to the body, so I don't think the vendors have them, but should not be hard to make for someone with the right tools, or possibly remove them from an existing body which is too bad to restore.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Fri Mar 11, 2022 8:01 pm
I salvaged 1 a few weeks ago when I was making 1 cowl out of parts from about 5. I will go see if I can lay my hands on it and if I can ,just help me out with the shipping.
I found it,it has a cut from the grinder on the side,can be welded up,still very rusty with dirt and the rusty sheet metal still riveted to it.
Dave Foley
First Name: David
Last Name: Foley
Post by Dave Foley » Sat Mar 12, 2022 9:09 am
I do need both sides, the previous owner was going to hot rod it and had removed them, thanks for the picture helps to see what im looking for
Will Brown
First Name: Will
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 26 Runabout
Post by Will Brown » Sat Mar 12, 2022 3:57 pm
Here is a much-enlarged shot of the brackets in question. The photos are hampered by a metal channel used to support the body when it was on the rotisserie. The metal channel is marked by the red arrow.
Post by TRDxB2 » Sun Mar 13, 2022 1:52 pm
??????? Looks like electrical metal channel ??? It comes in many sizes
Post by Scott_Conger » Sun Mar 13, 2022 1:56 pm
reread Will's post, Frank
Post by TRDxB2 » Sun Mar 13, 2022 2:22 pm
Are these what you need - recently listed on eBay so Hurry - seller is a good guy will take a reasonable offer - From Canada
https://www.ebay.com/itm/284699164209?h ... 8A&vxp=mtr
Post by Scott_Conger » Sun Mar 13, 2022 4:20 pm
and there they are, on a silver platter
