Rear Hub Puller
CatGuy
Topic author - Posts: 340
- Last Name: Hunt
- * REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Rear Hub Puller
I don't think I asked this before. At least I can't see that I did. In pulling the rear hub on my '26 Runabout with wire wheels, do I need to buy the threaded hub puller that is in the catalog or can I use a 3 finger style like the parts stores has?
Kevin Pharis
- Last Name: Pharis
Re: Rear Hub Puller
A 3 finger should work fine... as long as it is the type that bolts on with the lug nuts and designed for pulling hubs. An original would have slid into the reduced diameter portion at the end of the hub snout. The threaded pullers are for the wood wheel hubs, but could be the right tool for the job if your car has wood wheel hubs with wire wheel adapters.
Are your hubs threaded...?
CatGuy
- Last Name: Hunt
Re: Rear Hub Puller
I'll have to see if they are threaded. I can't recall just yet. I hadn't heard that the threaded pullers were for wood wheel hubs.Kevin Pharis wrote: ↑Mon Jul 18, 2022 11:52 amA 3 finger should work fine... as long as it is the type that bolts on with the lug nuts and designed for pulling hubs. An original would have slid into the reduced diameter portion at the end of the hub snout. The threaded pullers are for the wood wheel hubs, but could be the right tool for the job if your car has wood wheel hubs with wire wheel adapters.
jsaylor
- Last Name: Saylor
Re: Rear Hub Puller
You can buy this pitman arm puller from Harbor freight for $16.00. with a little grinding it makes an excellent puller for the wire wheel hub.
Re: Rear Hub Puller
You can buy this pitman arm puller from Harbor freight...
Does it fit the Model T pitman arm?
jsaylor
- Last Name: Saylor
Re: Rear Hub Puller
Unfortunately it does not fit the Model T pitman arm. It's too wide.
Flivver
- First Name: Steven
- Last Name: Park
Re: Rear Hub Puller
Yep, it works great!
Flivver, Paris Ontario CANADA
@flivverchannel
@flivverchannel
