Stewart Model 100 problem
Post by Steve Jelf » Mon Aug 29, 2022 9:38 am
My idiot email refuses to send a message to Russ, so I'll ask here.
I have my speedometer installed, but I haven't connected the cable to the swivel because of a malfunction. The swivel turns CCW, which I believe is correct. But it turns only when the wheel rotates backwards!
Have I installed the gears and swivel incorrectly?
Do I have the wrong swivel?
Re: Stewart Model 100 problem
Post by Original Smith » Mon Aug 29, 2022 10:54 am
Since you have a non original '15, is that why you wish to use a 100?
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Post by Russ_Furstnow » Mon Aug 29, 2022 11:36 am
Something is wrong with your internal gears. Turning your wheel in either direction should make the swivel output shaft turn. Give me a call since your email isn't working. Russ Furstnow
Post by Steve Jelf » Mon Aug 29, 2022 12:17 pm
I wish to use a 100 because I got it at a reasonable price, has an odometer, and is an aftermarket accessory that was sold for 1915-1918 Fords. I don't see that the impurity of my vehicle should preclude the use of a period accessory.
Post by Steve Jelf » Mon Aug 29, 2022 12:36 pm
Great. I found two phone numbers and both got a "cannot be completed as dialed" message. Maybe you can call me.
Three won sicks, 7 7 too, 7 fore too won.
