I am having an issue on my '15 bulb horn- when I squeeze the bulb normally I get backpressure and the bulb resists being squeezed which means very little (but good tone) sound. Its not all the time, but if I squeeze the whole thing= resistance, if I squeeze a portion of the bulb then it works.
Any idea what gives?
Jim
1915 Bulb Horn Blockage?
Re: 1915 Bulb Horn Blockage?
Probably the reed is stuck. Gently clean it, but don't mess with the flapper, or it may not work at all!
Fozz71
Topic author - Posts: 280
- Last Name: Chochole
- Board Member Since: 2003
What's the best way to clean a reed?
Or maybe a spider got in there somewhere and plugged it up. Ya never know!
Mountainrider
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Same problem,I moved my reed from just after the bulb down to just before the horn. Works great now
