FS headlight forks and front fender irons
T Cruiser
Topic author - Posts: 239
- First Name: Ted
- Last Name: VanBeek
- * REQUIRED* Type and Year of Model Ts owned: 27 Touring, 13 Touring, 10 Touring
These are nice original forks ,and correct fender irons for13-14. $150.00 plus shipping. These will fit in a large usps flat rate box. Call Ted at 503-728-3476
- Last Name: Wrenn
Re: FS headlight forks and front fender irons
More like '12-'13, IF indeed the extrusion between the lamp bracket hole and the frame mounting holes is fully round. The pic is hard to tell. In 1914 they changed the extrusion underneath the headlamp bracket hole which is now what I would call a slight "V" shape. And those style are a dime a dozen.
rickd
- First Name: Rick
- Last Name: Duquette
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Tim, is this the slight v-shape you are referring to on light bracket for a 14?
T Cruiser
- First Name: Ted
These are the later v style that was used in part of 13 and all of 14. My original un restored Feb. 13 has the early style,while a friend has Sept 13 has the later style. Many parts transitioned during 13. Ted
- Last Name: Wrenn
No, that pic is of the headlamp fork... I meant the actual fender iron. The area between the fork hole and the 3 holes where it bolts to the frame. Up til '13 that short area was round, after that it was in the shape of a "V". Hope this helps.
- Last Name: Wrenn
Kinda mis-typed there...not "up" til '13, meant to say "through" '13. Indeed, the very late '13s may have already had the "V" shaped iron, we all know how Henry did things. LOL
rickd
- First Name: Rick
I understand now. Thanks.
