Timing Cover Alignment Tool for 1912
Distagon2
Post by Distagon2 » Fri Jan 06, 2023 9:43 am
I am planning to change out the front timing cover on my 1912 to allow use of a "standard' timer versus the setup with an integrated oil spout. That takes me to needing an alignment tool. I have the tool for the later cars but the 1912 cover is different and requires a larger alignment tool that works by aligning the outer edges where the timer itself rides with the camshaft. I borrowed one years ago from Ken Jones and I believe it was an original tool. I looked at what the vendors offer and they all appear to be for later cars. Anyone know where I can find one, or have one I can borrow?
Distagon2
Re: Timing Cover Alignment Tool for 1912
Post by Distagon2 » Fri Jan 06, 2023 9:49 am
Hmmm, this might be the ticket: https://www.ebay.com/itm/225245735685
Last Name: Wrenn
Post by TWrenn » Fri Jan 06, 2023 10:19 am
One of the guys on here makes em and sells em. I got one but I forgot his name. It was either Dan Treace or Dan Hatch.
Post by RajoRacer » Fri Jan 06, 2023 11:09 am
Gene French produces the full size version.
Last Name: Wrenn
Post by TWrenn » Fri Jan 06, 2023 11:16 am
Yeah!! That's who I got it from! :lol: :lol:
Distagon2
Post by Distagon2 » Fri Jan 06, 2023 10:32 pm
Anyone have contact info for Gene French. I have found emailing and messaging through this site doesn't seem to work for me.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Sat Jan 07, 2023 12:46 am
It was in the eBay link.
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Post by Ralph F » Sat Jan 07, 2023 7:44 am
Just curious as to why a later timer alignment tool wouldn’t work?
Ralph
Distagon2
Post by Distagon2 » Sat Jan 07, 2023 8:57 am
The reason the later alignment tool won't work is because the area around the camshaft seal is different on the early cars than the later ones. If I can get some pictures together it would show it clearly.
I ordered one from the ebay link I already posted. Doh! It appears that is Gene French.......I ultimately get in focus!
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sat Jan 07, 2023 9:58 am
Gregory:
your centering gage is on it's way ... sent priority mail yeaterday ...thank you Gene French
